Tow bar tips
PostPosted: Sun Oct 12, 2008 1:03 am    Post subject: Tow bar tips Reply with quote
my job this week is to fit a tow bar, well make a tow bar too! I don't actually want it for towning trailers, just mounting a bike rack on, and for pulling the old car out of the shed, so it will have a pickup hitch attachment.
I am fitting it onto a Peugeot 306 Hatchback, anyone got any tips, before I get it up on the ramps, and start fabricating the bracketry. I take it I am to mount it to the boot floor with spreader plates inside, and maybe to any rails underneath, that look suitable?
PostPosted: Sun Oct 12, 2008 7:04 am    Post subject: Reply with quote
Hi Dave, most modern cars have mounting points for tow bars,normally for the side plates, which should make things a bit easier.
PostPosted: Sun Oct 12, 2008 8:14 am    Post subject: Reply with quote
Might be worth popping into your local towbar dealer and having a look at some schematic diagrams
ROVER
One of Britain's Fine Cars
Brian M
PostPosted: Sun Oct 12, 2008 9:46 am    Post subject: Reply with quote
I would definitely get to see where a genuine tow bar is attached to the car. Either talk to a tow bar supplier to see if you can get a look at the design, or find a car that has one fitted - for a 306, breakers yards may be a good place.
I once saw a tow bar that had ripped the rails off the back of a Datsun/Toyota type of car as the rails were designed only to collapse in a rear end shunt and not to pull anything and a home made tow bar was not transferring the loads correctly.
Brian
PostPosted: Sun Oct 12, 2008 10:03 am    Post subject: Reply with quote
I have a diagram from the net, that shows roughly where it has to go, but I am not going to have time to go to a yard, could perhaps ring a company up and have a chat, but they will probably just give me a diagram like I have if I am lucky.
I need the mounting plate for my bike rack next weekend, so it is something that will be done each night after work. I supose the other thing is to ask some of the mechanics at work, what they think.
PostPosted: Sun Oct 12, 2008 1:45 pm    Post subject: Reply with quote
hi
I hope you are going to use a trailer board for lights and number plate.
It is amazing how many cyclists think that glimpsing the lights a reg through two or three wheels/frames is sufficient.
PostPosted: Sun Oct 12, 2008 6:51 pm    Post subject: Reply with quote
I will indeed, I have lots of trailer boards that I am able to use.
PostPosted: Sun Oct 12, 2008 7:26 pm    Post subject: Reply with quote
What are the regulations for having bicycles on racks that stick out eitherside of your car, is this ok?
PostPosted: Sun Oct 12, 2008 7:46 pm    Post subject: Reply with quote
I think they come under the standard abnormal loads regs.
Quote:
An abnormal load fits any of these categories:
A loads projecting more than 305mm (12in either side of the vehicle).
A vehicle or load exceeding 2.9m (9ft 6in) in width.
A vehicle or load exceeding 18.3m (60ft) rigid length.
A motor vehicle, trailer and load together exceeding 25.9m (85ft) in length.
A load projecting more than 3.05m (10ft) over the front or rear of the vehicle.
A vehicle or vehicle and load exceeding 76,2000kg (75 tons) gross weight.
so you should be alright if less than 12" protruding.
from http://www.iam.org.uk/motoringtrust/news/archive/2004/abnormalloadscouldjamupthenetworksaysaamotoringtrust.htm
I believe the max distance of rear position lights from the edge of the vehicle is 100mm for the outer edge of the lights.
PostPosted: Sun Oct 12, 2008 9:00 pm    Post subject: Reply with quote
And I supose that is past the widest point, my wing mirrors?
I will have to widen a tail board or build some lights into my rack perhaps, could turn into quite a fancy rack this! hehe
PostPosted: Tue Oct 14, 2008 11:12 pm    Post subject: Reply with quote
Well the towbar is on, took all of 50 mins, handy having a ramp.
