GEARBOX OIL SEALS
heathelect
PostPosted: Fri Dec 19, 2008 5:37 pm    Post subject: GEARBOX OIL SEALS Reply with quote
HELP NEEDED, Can anyone tell me where i can purchase oil seals and gaskets to fit the gearbox of my ford consul classic ? please
PostPosted: Fri Dec 19, 2008 11:51 pm    Post subject: Reply with quote
Virtually all oil seals are standard stock - take the old ones to a bearing supplier and they will match up.
If gaskets are NLA (have you tried the Owners Club?) make your own from gasket paper or even cartridge/writing paper depending on what was one.
Just cut roughly to shape place over casing and lightly tap round with a steel hammer and it will cut exactly to shape. use a ball-pien hammer for holes or buy hole punches or make some out of tubing
A lot of gearboxes use the paper sort.
Rover P2
Morris Mini Traveller Mk2
PostPosted: Sat Dec 20, 2008 11:12 am    Post subject: Reply with quote
On the subject of seals, Aldi (of all places!!) are selling "O" ring kits in both metric and imperial sets, about 700 rings per kit for £6! I bought a set of both.
wrinx
PostPosted: Sat Dec 20, 2008 7:40 pm    Post subject: Reply with quote
Yup, did exactly that for my driveshaft seals...still flamin' leaked though! Rolling Eyes Laughing
wrinx
www.alfaromeo155.co.uk | www.alfamatta.co.uk
PostPosted: Sat Dec 20, 2008 11:45 pm    Post subject: Reply with quote
Same place will sell bearing shaft sleeves - thin shim steel tubes in exact sizes to give new wearing surface for seal to run on. Not tried them though and they may be expensive. I had a lonk but cannot find it now
Rover P2
