triumph vitesse
Poppet
PostPosted: Fri Dec 19, 2008 6:24 pm    Post subject: triumph vitesse Reply with quote
Hello
I have a triumph vitesse MK2 1968 2 litre 6 cylinder.
I have a problem:
I started the car this am but only made it to the end of the road when she completely lost power. The engine was still running but seemed either completely choked or petrol starved. I have recently had the twin Strombergs serviced and until this am she has run beautifully. Has anybody got any ideas please?
Thanks in advance
Steve
PostPosted: Fri Dec 19, 2008 7:15 pm    Post subject: Reply with quote
Hi Steve, welcome to the forum.
When the carbs were serviced, were the diaphragms in the Stromberg carbs replaced? splits in these can cause erratic running.
PostPosted: Sun Dec 21, 2008 4:14 pm    Post subject: Reply with quote
Hi Poppet, you will have to give us a bit more. Will the engine rev? Is the engine missfiring. Is there smoke? Is it rattling? Have a look at the dizzy, can you turn it by hand? Gently pull the HT leads, are any loose. good luck
Poppet
PostPosted: Sun Dec 21, 2008 4:41 pm    Post subject: triumph vitesse Reply with quote
Thanks for all your helpful advice - managed to sort the problem - discovered the car was only running on one carburettor! Further investigation revealed the float chamber needle valve had stuck in the off position.
Steve
PostPosted: Sun Dec 21, 2008 9:37 pm    Post subject: Vitesse Reply with quote
Hi Poppet, glad you got it sorted. I have always liked the Vitesse. Here is a rather nice one at the Newmarket Classic Car Club.
Umm, nice. Thats my Midget next to it.
