jensen541
Posted: Mon Jan 19, 2009 5:45 pm Post subject: Core Plug Sealant |
Evening
I have removed the core plugs from the Jensen block as it seemed prudent with the engine was out and one section between plugs was completely blocked, so I'm glad I did. There seemed to be some type of core plug sealant in there, looked like silicone to me. Is that correct or is there something better?
Also I will be replacing both crank and rod bearings. I know there is a thread further down regarding grease (thought that covered wheel bearings?) but what would to blokes suggest be better, graphite grease or lithium for the these bearings?
Ta |
Posted: Mon Jan 19, 2009 6:17 pm Post subject: |
Red Hermatite - Silicon is just about OK if casting face is badly pitted/corroded but will soon start leaking again _________________ Rover P2
jensen541
Posted: Mon Jan 19, 2009 6:43 pm Post subject: |
| Cheers Phil. Got some that somewhere. |
