Remains of an early Jaguar?
PostPosted: Wed Feb 18, 2009 2:32 pm    Post subject: Remains of an early Jaguar? Reply with quote
Just post-war?
Found recently, it definitely looks like it has been there a looooong while!
PostPosted: Wed Feb 18, 2009 3:04 pm    Post subject: Reply with quote
Rick,
I don't recognise this as any Jaguar. I've checked my Eric Dymock Jaguar File and there isn't anything like this there. It does have an SS2 look about the rear end but they were 2 door cars. There doesn't appear to be any SS cars with steel wheels either. The engine obviously is a 2.4 litre twin-cam XK unit. The earliest of which appeared in 1955. Do you know what it was registered as? Does anyone recognise the dash?
Art
PostPosted: Wed Feb 18, 2009 3:55 pm    Post subject: Reply with quote
I was pondering about this being a bitsa, as I didn't spot any Jaguar markings elsewhere, but there are signs of other Jaguars dotted around the undergrowth so thought I'd see if anyone else recognised it?? if I get chance I'll go back and look for a chassis/bulkhead plate Smile
(from the road I thought it was a Rover, but the engine threw me somewhat)
PostPosted: Wed Feb 18, 2009 4:04 pm    Post subject: Reply with quote
It's a Rover, P2 I think, fitted with an XK engine.
Glenn Crawford
PostPosted: Wed Feb 18, 2009 5:09 pm    Post subject: Reply with quote
Exactly what I thought when I saw it Peter! As such, the engine might be of use to someone I suppose, but a rotten P2 Rover isn't for saving I'm afraid.
PostPosted: Wed Feb 18, 2009 5:27 pm    Post subject: Reply with quote
Smile and thats the good side!
I plan to make some enquiries, as the building behind isn't exactly empty either
PostPosted: Wed Feb 18, 2009 6:40 pm    Post subject: Reply with quote
Looks familiar to me!
PostPosted: Wed Feb 18, 2009 7:40 pm    Post subject: Reply with quote
It's a P2 sport saloon
ROVER
One of Britain's Fine Cars
PostPosted: Wed Feb 18, 2009 7:46 pm    Post subject: Reply with quote
Easy clean steel wheels would indicate post war, dashboard going to a peak at the bottom indicated up to early 1947 as the dash was changed later in 47 to accommodate a radio.
To sum up a Rover P2 either 14hp or 16hp fitted with a Jaguar 2.4 litre twin-cam XK engine. Date somewhere between 1945 and 1947
Unless anyone else knows better
ROVER
62rebel
PostPosted: Sat Mar 14, 2009 1:52 am    Post subject: Reply with quote
the odd lever to the right of the steering wheel; is that for a preselector gearbox, or am i reading too much into what i see? that dash, by the way, looks great and i hope it at least will be snatched up.
PostPosted: Sat Mar 14, 2009 11:27 am    Post subject: Reply with quote
62Rebel,
I think that's the lights switch.
Art
PostPosted: Sat Mar 14, 2009 1:07 pm    Post subject: Reply with quote
The lever on the right of the steering is the semafore trafficator switch
The dashboard on the P2 is rather nice 62rebel
ROVER
