Morris 8 Series one in Essex or South Suffolk?
Timstopp
PostPosted: Thu Mar 12, 2009 5:19 pm    Post subject: Morris 8 Series one in Essex or South Suffolk? Reply with quote
Does anyone know of a Morris 8 series one in either North Essex or South Suffolk(private or in a museum) that I could take a look at.
I have been trying without success to establish if the running gear and chassis is the same as on a Wolseley Nine (Rumour has it that it is, but before I order any parts....)
I have tried both The Wolseley Register and The Morris club, but have not been able to get a definitive answer.
Many Thanks
North Essex,UK - Morris 8 tourer 1936 - Jaguar x350
PostPosted: Thu Mar 12, 2009 5:58 pm    Post subject: Reply with quote
I have the Morris Illustrated parts book if you want anything referencing?
Cheers Dave
Timstopp
PostPosted: Thu Mar 12, 2009 7:04 pm    Post subject: Reply with quote
Thanks for that, I am not sure how that would work unless Wolseley and Morrris used the same part no's. Perhaps you could check for me?
For instance track rod (rh thread) - m4923a
rear spring shackle pin - m7574a
Those are two of the many parts that I am likely to need Sad
PostPosted: Thu Mar 12, 2009 7:49 pm    Post subject: Reply with quote
Timestop,
I would think so. Pre BMC they were known a MOWOG parts. (Morris/Wolsely????)
Art
Timstopp
PostPosted: Fri Mar 13, 2009 10:11 am    Post subject: Reply with quote
thanks 47 jag,
thats just my point, most people think so, or assume it to be the case, but no one can definitely say yes or which parts, which is what I need before I can spend lots of money ordering parts.
So I thought the simplest way may be for me just to look for myself.
Giggles
PostPosted: Mon Mar 30, 2009 4:48 pm    Post subject: Reply with quote
If you're still having problems, try contacting NTG on Bramford Road in Ipswich. They specialise in Austin, Morris and the like. They might be able to advise you.
1953 Humber Hawk
1955 Ford Fairlane
1960 & 1963 Humber Super Snipe's
Nic Jarman
PostPosted: Tue Mar 31, 2009 11:41 pm    Post subject: Reply with quote
Hi, Suffolk is long and thin so south suffolk is quite a long strip. Is near Haverhill any good to you?
You are welcome to visit and the kettle is always hot,
Giggles
PostPosted: Thu Apr 02, 2009 1:28 pm    Post subject: Reply with quote
If it helps Ipswich is south east Suffolk Wink
1953 Humber Hawk
1955 Ford Fairlane
