yorkshireretro
Posted: Sat Apr 04, 2009 9:42 pm Post subject: Waterpump / Footpump |
I bought a tiny 70's 10ft ci Cadet caravan today and it has the old style water foot pump which sucks up water from a tank at the back of the caravan when you pump it. I tried it and it didnt suck anything up!! any ideas anyone?  |
Posted: Sat Apr 04, 2009 10:57 pm Post subject: |
They usually have a rubber flap valve in them which may be worn. Try hand priming the pump first to see if it works _________________ ROVER
One of Britain's Fine Cars |
emmerson
Posted: Sun Apr 05, 2009 5:52 pm Post subject: |
| As 47p2 says, it's probably just dried out from lack of use. Give it a soak and it should be OK |
Brian M
Posted: Sun Apr 05, 2009 7:20 pm Post subject: |
Had one on my previous Knowsley, and my local camping shop had a refurb kit with new washers, valves etc.
You can replace it with the Whale electric submersible pump that you drop into the outside water tank. _________________ Brian
