waxoyl time
Finch661
PostPosted: Mon Apr 20, 2009 3:13 pm    Post subject: waxoyl time Reply with quote
after peering under my mini, i noticed a fair bit of surface rust (no holes thankfully). i am going to be treating as much ot the car as i can. my plan is to paint the underside of the car (and subframe) with hammerite underseal with added waxoyl (the stuff in a red and black tin). then for all the nooks and hidyholes, i have bought some general waxoyl for a compressed air shultz gun. i am planning to coat the suspension and wheel arches with this
does this sound ok? oh and what preperation is needed before waxoyling/undersealing?
many thanks
Kelsham
PostPosted: Mon Apr 20, 2009 5:26 pm    Post subject: waxoyl Reply with quote
Hi I would treat the rust and pint with primer and topcoat first.Using waxoyl on rusty metal just hides it. Regards Kels
Brian M
PostPosted: Mon Apr 20, 2009 8:11 pm    Post subject: Reply with quote
Some years ago I was told that as waxoyl contains silicones you should never apply it before respraying as cellulose reacts with the silicone.
Is this true?
And does 2 pack or water based paint react in the same way?
Brian
SV8Predator
PostPosted: Mon Apr 20, 2009 8:28 pm    Post subject: Reply with quote
Is this true?
Yes, every sort of paint can suffer silicone contamination, known in the trade as 'fish-eyes', little craters in the paint surface.
Thats why the cleaned primer is wiped with a 'prep-sol' or spirit-wipe to remove these surface contaminants, but often with silicone contamination that's not enough. Indeed someone using a silicone polish or spray in the vicinity can ruin a paintjob as the contaminant has become airborne.
A silcone additive can be added to the paint to make it flow better if there has been a previous silicone reaction (the fish-eyes).
2000 Jaguar XJ8 4.0 LWB
1974 Jensen Interceptor Mk III
1969 Jensen Interceptor Mk I
Finch661
PostPosted: Mon Apr 20, 2009 11:10 pm    Post subject: Reply with quote
whats a good (and cheap) rust treater/primer?
bob2
PostPosted: Tue Apr 21, 2009 9:06 am    Post subject: Reply with quote
I have used some products from bilt hamber and found out they have good quality material!!
Have got to know about them from this forum thanks to greeney!!
HEres the link to there website;
http://bilthamber.com/shoppingbasket.php
Finch661
PostPosted: Tue Apr 28, 2009 12:24 pm    Post subject: Reply with quote
hey thats the inside of my mini back togeather. i found kurust was quite useful, coated in that stuff first, repaired the odd hole, painted in straight to rust paint, foot wells were coated in tetroseal then a final coat of waxoyl. the interior looks brand new Razz
