Finch661
Posted: Thu May 07, 2009 10:01 am Post subject: starter for engine swap |
i am going to be swapping my 998cc mini engine for a metro 1275 engine, the engine was in my car before (before i bought it though) so it has the right mounts and everything. i am a little confused because of the starter motor/clutch.
both engines have a verto cluch (small lever out side the casing), the 998 has a pre-engaged starter, but the flywheel on the 1275 has 107 teeth, which is common for a pre-verto....
anyone give me any advice? i would like to keep the pre-engaged starter, but i could fork out and get an old inertia styled one
thanks |
Posted: Thu May 07, 2009 10:29 am Post subject: |
Finch,
Normally pre-engaged starters have a chamfer on the flywheel facing forward. The inertia starters have the chamfer on the rear. The chamfer is to help the pinion teeth mesh easily. If the flywheels are not swappable then fit a new ring gear to the flywheel you need but with the chamfer reversed.
Art |
Finch661
Posted: Thu May 07, 2009 12:05 pm Post subject: |
| hmm is it hard to fit a new ring-gear, or would it be easier to fit a new small gear to the starter? |
arossco
Posted: Thu May 07, 2009 12:25 pm Post subject: |
| The pre-engaged starter meshes with the front of the ring gear but the inertia starter meshes from behind - so changing the only starter gear would not be enough. |
Finch661
Posted: Thu May 07, 2009 12:36 pm Post subject: |
| in my mind (i am daft though), the verto flywheel from my998 should be the same as the flywheel from my 1275 (also a verto), the only diff being the ring-gear. could i not take take the flyweel of the 998 and put on the 1275? |
Posted: Thu May 07, 2009 1:07 pm Post subject: |
| Quote: | Could I not take take the flyweel of the 998 and put on the 1275?
Finch,
I said that. They would have to be the same tooth count and diameter tho'. Is the flange hole for the starters the same diameter on both blocks??
Art |
Finch661
Posted: Thu May 07, 2009 2:34 pm Post subject: |
sorry, i misread what you said.
em i dont know about the starter holes, would need to see when the 998 comes out |
