Fuel tank sender units
PostPosted: Thu May 28, 2009 10:49 am    Post subject: Fuel tank sender units Reply with quote
Hi all
I need to find 2 new top-mounted 6v senders to fit on the Dodge's tanks. They are a five hole fixing - do all five-hole senders have the same fitting dimensions?
ta, Rick
stuchamp
PostPosted: Thu May 28, 2009 3:17 pm    Post subject: Reply with quote
Rick, never heard of a 6v fuel sender, but I understand what you're after. Smile
They are usually based on their ohms.
Check your service manual for readings.
Stewart Warner Company provides the universal type senders that you will need.
http://www.stewartwarner.com
http://www.stewartwarner.com/Catalog/fuelsdrs90.html
http://www.stewartwarner.com/Catalog/fuelsdrs240.html
A lot of the large tanks back then used the same fuel senders, GMC, Ford, International, etc.
Original senders may still be available.
stuchamp
PostPosted: Thu May 28, 2009 3:26 pm    Post subject: Reply with quote
Also check here....
http://www.vintagepowerwagons.com/
Bet you can find ones the same as yours.
PostPosted: Thu May 28, 2009 6:33 pm    Post subject: Reply with quote
Sorted now (I think). A look at the local '40 Chevy showed that it had the same fitting, and so too do the WW2 Jeeps so I paid a visit this pm to Jeeparts, and picked up a couple that, with a slight modification, should do the job Smile
