Glass Window Needed.
captinbash
PostPosted: Wed Jun 17, 2009 10:58 pm    Post subject: Glass Window Needed. Reply with quote
Hello All, I am in need of a replacement window for my viking 2 berth, it is fitted with a non-opening glass in aluminium frame in an opening size: 24" tall and 15" wide, square at the top and radiused at the bottom, I would like to ask you all to do me a favour and keep your eyes open and check your spares to see if there is one out there that I can buy please, Thanks.
moggy
PostPosted: Thu Jun 18, 2009 1:26 am    Post subject: window Reply with quote
Hi maybe a picture of the one fitted may help so we can maybe suss out one !
View user's profile Send private message Send e-mail MSN Messenger
Uncle Alec
PostPosted: Thu Jun 18, 2009 8:29 am    Post subject: Reply with quote
Usually quite easy to dismantle the frame and have new glass cut by any glass merchant.
old van man
PostPosted: Thu Jun 18, 2009 5:37 pm    Post subject: Reply with quote
Dont know why but this window always seems to be cracked or broken on fiberlines, i found the best method is like uncle alec says , remove the window complete, strip the frame, usually two small slotted screws in the corner of the frame , take out the broken glass, make a cardboard template, and have a new window glass cut , you may need a new window seal as the old one will have shrunk! , i have obtained these in the past from "Wolleys" classic car spares
good luck ! Smile
captinbash
PostPosted: Thu Jun 18, 2009 6:11 pm    Post subject: glass window needed Reply with quote
Thanks for all the advice it is really helpful. I have removed the rear windows to replace the rotten wood surround and have examined these and found the screws mentioned so when the rear windows are back in I will start at the front ones.
I will post some pictures of 'progress so far' soon.
Thanks again.
PostPosted: Thu Jun 18, 2009 7:45 pm    Post subject: Reply with quote
From looking at the pics of Fibrelines and the decription in the Capt's Hello All thread, I take it that it is the O/S front flat window.
That is going to be the one most likely to get hit by stones thrown up by other traffic.
Also, I wonder if ordinary window glass is up to the flexing in a mobile situation, the other small front window being in a separate opening frame would have more tolerance.
Is there a perspex alternative which might be more durable, I have some polycarbonate, for instance which is as clear as glass, it is quarter inch thick but does have a degree of flexibility.
European Voyager
PostPosted: Sat Jun 20, 2009 5:33 pm    Post subject: Reply with quote
The window on my Viking caravan broke I went to a plant glazing company and they cut it and shaped it no problem for me , There may be a company like that near you .
