Exhaust Gas Analyser
PostPosted: Tue Jul 14, 2009 10:35 pm    Post subject: Exhaust Gas Analyser Reply with quote
I picked up one of these at Glamis. Needless to say it doesn't work. Does anyone happen to have operating instructions or principles of operation for it?
PostPosted: Wed Jul 15, 2009 10:13 pm    Post subject: Reply with quote
Hi Peter
If its anything like an older one that I have its based on a wheatstone bridge , the co2 sensor generates heat (from a catalitic reaction with C02) and a thermistor fixed on the sensor changes resistance, this resistor is part of the bridge and the meter is the galvonometer across the bridge.
Hope this make sence!!
Cheers Dave
PostPosted: Thu Jul 16, 2009 12:34 am    Post subject: Reply with quote
Thanks for replying Dave. I'll give your description some thought. Actually since reporting it faulty I discovered that I was missing one of the water collectors on the rear but fortunately my wife came up with a suitable shampoo bottle and the analyser appears to be working. It has two scales,
0-2% and 0-10% and it has a more prominent graduation at 4.5%.
I'm not sure what reading I should calibrate it to in fresh air but have been using a value of 2% as this figure is used in the Gunsen analysers.
Do you happen to know what calibration reading is correct and what the significance of the 4.5% is?
Thanks,
PostPosted: Thu Jul 16, 2009 10:39 am    Post subject: Reply with quote
Hi Peter
I have a couple of these things, a Gunson one where as you say is calibrated to 2% in fresh air and one on a Crypton tuner where you set it to 0%. By way of a check you could see what reading it gave on something that has just had an MOT where an emmisions test has been done, adjust to match the MOT reading and then see what the fresh air reading is?
The significance of the 4.5% is that this relates to what C02 the optimum 14.7:1 mixture ratio will produce.
PostPosted: Thu Jul 16, 2009 12:24 pm    Post subject: Reply with quote
Thanks Dave.
P.
