jessejazza
Posted: Fri Jul 20, 2012 10:56 pm Post subject: Hazard lights--when unavailable for a certain - alternative? |
I've just spent a couple of days trying to work out how to replace the now unavailable knackered switch for an alternative- aperture dimension 20 x 50 mm.
a] i'm not quite sure how the circuit works - the switch is basically an off-on but one has six spades 4.8mm.
b] there are switches available [kit car ones from folk like Europaspares] but either wrong aperture dimensions, 6.3mm spades (minor problem replacing the 4.8mm spades), or terminal block but difficult to work out [for me!] which is required.
c] But some switches have a different number of terminals? On this one it's six which are the following... as best as i can make out from the wiring diagram
six connections
- hazard flasher unit
- indicator front RH and rear RH
- to joint
a] indicator front LH and rear LH
b] column multiswitch
- indicator flasher unit
- supply from fuse box
- hazard warning light
e.g.
https://www.europaspares.com/product/0/14808/Delta_Rocker_Switches.html
https://www.europaspares.com/product/75/17817/ELECTRICAL/SWITCHES/Led_Hazzard_Switch_Red___Wl4014.html
How can this work with just three terminals?
http://www.vehicle-wiring-products.eu/VWP-onlinestore/switches/rocker.php
this one has the correct number of terminals and i'm just thinking how to pad out the 20 x 50 mm original aperture.
I'm hoping someone else has had this dilemma and can advise. Seems to me a common problem developing. Switches for heated rear window, fog lights etc are easily got round with common basic one pole or double pole.
many thanks |
Inglewood
Posted: Sat Jul 21, 2012 7:21 am Post subject: |
If you can find a switch but with the incorrect size connectors, and you do not want to modify the vehicle loom, make up a short adapter loom using the necessarily male/female connectors. |
Posted: Sat Jul 21, 2012 1:36 pm Post subject: |
How about using a relay with enough contacts to mimic the operation of the original switch. Then use the best aesthetic switch to turn the relay on.
As already suggested, create a small harness to join the existing connectors to the relay. Doing this would allow an original switch to be easily installed if/when found. |
jessejazza
Posted: Sun Jul 22, 2012 12:43 am Post subject: Re: Hazard lights--when unavailable for a certain - alternat |
The Delta switches seem the best option as they are comprehensively available.
Good suggestion about the relay but i'm unlikely to get an original switch. At least the Delta range cover a good range and are likely to be available for some while yet. |
Posted: Sun Jul 22, 2012 10:13 am Post subject: |
The 3 terminal switch is for a remote special relay.
The circuit is simple really and there are various alternatives.
What car have you got as all sorts of s/h ones turn up on Ebay _________________ Rover P2
jessejazza
Posted: Mon Jul 23, 2012 1:32 am Post subject: |
Phil - Nottingham wrote: | What car have you got as all sorts of s/h ones turn up on Ebay |
You'd laugh if i told you. I'm going to get the Delta switch as the aperture is the same as the brake test switch (which i've now done away with as i've fitted a single circuit system).
Delta switches are widely available for kitcars etc and the only alternative is SWF but they are much more expensive and not so readily available e.g. vehicle wiring but i don't know of anyone else. |
