OT: PC lost in time
PostPosted: Wed Sep 16, 2009 10:24 am    Post subject: OT: PC lost in time Reply with quote
Computery-type question now, of late my PC seems to "lose" 1hr on it's internal clock on a fairly regular basis when I switch on. If I update it, the time shows correctly for the rest of the session.
I could understand perhaps a battery backup throwing a wobbler, and the time resetting to say 00:00 or 12:00, but why it loses exactly 1hr is beyond me???????? Surely it doesn't keep thinking that it's time for putting the clock back?
PostPosted: Wed Sep 16, 2009 12:19 pm    Post subject: Reply with quote
Did you correct it in the BIOS ?
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Wed Sep 16, 2009 12:26 pm    Post subject: Reply with quote
nope, at least I don't think so Confused
PostPosted: Wed Sep 16, 2009 2:17 pm    Post subject: Reply with quote
When you start your PC it should say "press ( sometimes F2 or Esc or Delete ) to enter BIOS". If not check your manual. Correct the time in your BIOS but DO NOT touch anything else. Sometimes the manufacturer puts a splash screen over the instructions so RTFM.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
traction39
PostPosted: Wed Sep 16, 2009 2:38 pm    Post subject: Reply with quote
Are you updating the time from "internet time" and in a different time zone? Just a thought...
Alistair
Riley 9 Special 1932
PostPosted: Wed Sep 16, 2009 8:39 pm    Post subject: Reply with quote
Rick,
Go into Control Panel and check the date (you can check the time zone too). It may have switched from summer time if the date is wrong.
Art
PostPosted: Thu Sep 17, 2009 8:30 am    Post subject: Reply with quote
what OS are you using? some versions of linux and later MS windows use 2 clocks; a bios clock which will always creep a tad and an OS clock which may use the bios clock but can be pointed to any time server on't interweb for correction.
If it jumped forward an hour it would look like CET time, back an hour is Auckland time! not very common Shocked
PostPosted: Thu Sep 17, 2009 9:04 am    Post subject: Reply with quote
Thanks for the tips, it seems ok today so will keep an eye on it. I'm on XP btw
