TriciaS
Posted: Mon Jan 30, 2017 5:42 pm Post subject: how to search posts ??????? |
| I am having real problems and whatever I search for I always just get every post ever written with none covering the subject I need, how do I use th search and actually get to a post with similar problems and answers |
Posted: Mon Jan 30, 2017 5:50 pm Post subject: |
Bottom left of the search page:
| Quote: | | Display results as: O Posts O Topics |
Put a black dot in the Posts circle, Topics is the default. _________________ Bristols should always come in pairs.
TriciaS
Posted: Mon Jan 30, 2017 6:39 pm Post subject: |
| Penman wrote: | Hi
Put a black dot in the Posts circle, Topics is the default. |
I did that still no luck |
Penguin45
Posted: Mon Jan 30, 2017 7:20 pm Post subject: |
If you type in "hillman dynamo", you get 840 results.
If you type in "hillman AND dynamo", you get 3 results, as the search facility is looking for those two words together, as opposed to every post with Hillman and every post with dynamo.
Hope that makes sense.
Posted: Mon Jan 30, 2017 8:51 pm Post subject: |
The renowned Boolean Search protocol; as well as AND you can also use OR and NOT as separators. _________________ Bristols should always come in pairs.
