Pat Russell
Posted: Tue Oct 20, 2009 6:37 pm Post subject: Easy steering with a horse box /caravan or trailer. |
This may be well known to drivers that tow things.
Our garden is not the easiest to steer a horsebox/caravan or trailer into especially into the space down the side of the house.A boat owner friend of ours suggested I put a tow hitch on the front of my landrover . This makes parking so easy hitch the trailer on the front and you can see exactly which way it is going...I bet all you members know this already but some may not.
Pat |
Posted: Thu Oct 22, 2009 10:45 pm Post subject: |
How can you see if you are pushing a caravan or horsebox.Its bound to block your view. Whereas if you are reversing in you can see where you are going through your wing mirrors.  _________________ The Clan Chieftain |
Brian M
Posted: Fri Oct 23, 2009 7:32 am Post subject: |
The 1966 SWB Land Rover that I occasionally borrow from a friend has two front tow balls. One in the centre if you are squeezing the outfit into a tight space and one about two feet towards the passenger side so you can see alongside whatever you are pushing.
He uses it in his boatyard and as Pat says it really does help with precison manoeuvring. _________________ Brian
Pat Russell
Posted: Fri Oct 23, 2009 7:38 am Post subject: not a problem |
| 71marina wrote: | How can you see if you are pushing a caravan or horsebox.Its bound to block your view. Whereas if you are reversing in you can see where you are going through your wing mirrors.  |
I used to use this method when I had already decided where I needed to park and check it was clear. In our garden I had to negotiate a long curved drive ,low walls either side of the drive and then into a narrow gap down the side of the house.I could see exactly where I was going and could easily avoid touching the walls.I was doing all of five miles an hour .Mind you the men in the family could do this easily by using the mirrors.Useful also for rescuing friends out of the mud.I do not have to go into the mud just use a tow rope P. |
Pat Russell
Posted: Fri Oct 23, 2009 7:43 am Post subject: Thanks |
| Brian M wrote: | The 1966 SWB Land Rover that I occasionally borrow from a friend has two front tow balls. One in the centre if you are squeezing the outfit into a tight space and one about two feet towards the passenger side so you can see alongside whatever you are pushing.
He uses it in his boatyard and as Pat says it really does help with precison manoeuvring. |
Thanks...I'm pleased someone else has successfully used this method . P. |
Posted: Fri Oct 23, 2009 10:57 am Post subject: |
Having driven articulated trucks with 45' trailers for a number of years I wouldn't find a need for this but I could see it being of advantage to someone who isn't used to reversing a trailer _________________ ROVER
One of Britain's Fine Cars |
Pat Russell
Posted: Fri Oct 23, 2009 11:18 am Post subject: Thanks again |
| 47p2 wrote: | | Having driven articulated trucks with 45' trailers for a number of years I wouldn't find a need for this but I could see it being of advantage to someone who isn't used to reversing a trailer |
How splendid !I have always admired folks like you making it all look so simple.Although I have towed a 22 foot glider trailer ,only once in an emergency.But there would be no way I could have reversed that into a confined space.My husband did it without any problem.
Thanks for yet another interesting answer P. |
Posted: Fri Oct 23, 2009 4:19 pm Post subject: |
The advantages of front mounted hitches has little to do with the ability to reverse a trailer.
By having the steering wheels of the vehicle closer to the trailer one can place the trailer into a position that is just not possible when reversing. |
Posted: Fri Oct 23, 2009 8:27 pm Post subject: |
I have noticed that a lot of what I believe are called Wagon and Drag rigs, whether close coupled or those with a pivoting front axle on the trailer, have a hitch in the centre of the front bumper.
Presumably it makes it easier to position the trailer into a loading bay and then put the wagon in a second bay for quicker unloading of both components. _________________ Bristols should always come in pairs.
Posted: Fri Oct 23, 2009 9:33 pm Post subject: |
A neighbour who is dissabled and a caravaner, uses something like this to move his van around to the back of the house
http://www.rhynomovers.com/ |
Posted: Fri Oct 23, 2009 10:11 pm Post subject: |
I've never tried reversing a wagon & drag so I'm unable to verify this for you Penman _________________ ROVER
Posted: Sat Oct 24, 2009 10:42 am Post subject: |
| Penman wrote: | Hi
Presumably it makes it easier to position the trailer into a loading bay and then put the wagon in a second bay for quicker unloading of both components. |
A waggon with two or three trailers, showmen can only reverse the full load about 3 feet without having to draw forward, then try again, it is a nightmare! |
Posted: Sat Oct 24, 2009 10:46 am Post subject: |
Having a towbar on the front bumper also makes the steering wheels closer to the unit, so in effect a rear steared vehicle, which responds quicker, in my oppinion.
Reversing with a stacker truck is the same, although I numally put it on the front tines and push it.
Having the towbar offest to one side is good if you have the space, but it still pays to have a banksman so to speak.
You want to try backing a combine, with the header behind it or heres another a steam roller with watercart.
Pat Russell
Posted: Sat Oct 24, 2009 10:54 am Post subject: Amazement |
| buzzy bee wrote: | Having a towbar on the front bumper also makes the steering wheels closer to the unit, so in effect a rear steared vehicle, which responds quicker, in my oppinion.
I'm amazed at the response to my original message. Thanks to all.P. |
poodge
Posted: Sun Oct 25, 2009 9:09 pm Post subject: |
[quote:have a hitch in the centre of the front bumper. ]
In actual fact,these fittings are to tow the vehicle when disabled.They are however also useful for the purpose stated,i.e. reversing the trailer.However,it seems reversing isn't neccessary as often as it used to be.[/quote] |
