Mello
Joined: 24 Aug 2009 Posts: 34 Location: Lower Normandy, France
Posted: Tue Nov 03, 2009 10:20 am Post subject: Use of electric fans on thermally-cooled Pop? |
My Pop doesnt have a water pump and is cooled by the natural progress of heated water through the rad and back through the engine. Would it be an improvement/assistance to this process to add a thermostatically-controlled electric fan onto the radiator? I know this helps pumped cooling systems, but I'm wondering if it would have the same beneficial effect on a thermo-syphon cooling system?
I'm guessing it would be helpful, but has anybody tried it??  |
Posted: Tue Nov 03, 2009 1:41 pm Post subject: |
|Mello,
I'm sure if you look around you might find a water pump for it. They were fitted to export models of the Anglia (and probably Prefects) and were available here as an option. My uncle had one on his Anglia.
Art |
Posted: Tue Nov 03, 2009 1:53 pm Post subject: |
For the most part a correctly working thermosyphon cooling system is OK. If you are experiencing overheating you need to check out why. If you use the vehicle in a lot of slow moving traffic foe example a fan may help. I have recently been discussing this with the folks at Kenlowe for a specific application. They were most helpful
PAUL |
Posted: Thu Nov 05, 2009 3:32 pm Post subject: |
What voltage is your Pop? I was thinking about the same thing for my 8, and I may bolt a 4 blade fan onto the dynamo. Always use de-ionised water and anti-freeze. _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
Posted: Sat Nov 07, 2009 11:51 pm Post subject: |
Fans do very little to help the cooling of any water cooled engine with a front radiator while the vehicle is in motion. Being a means of preventing overheating when stationary. Which is why viscous fans and feathering fans were popular before electric fans took over. Much better effect would be investigating the posiibility of an aftermarket water pump or ducting as much air as possible into the radiator.
These cars ran happily for years as built. If overheating is occuring now I would suspect radiator blocking both for water flow and AND air flow through the radiator matrix. The idea that flies and leaves etc in the radiator matrix may be significant seems to be often overlooked. Other overheating causes may be ignition timing or carburation. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
Posted: Sun Nov 08, 2009 12:23 am Post subject: |
I would wash the core of the radiator externally, then if it is suspected as being blocked, boil it up etc.
I looked into fans, and a good way to mount a fan is inside the grill infront of the rad, pushing air through, I know it may interupt the air flow a little, but there is normally lots of room in this area, and they are quite big radiators, being thermo syphon. Have a look at a motorbike fan, can be picked up cheaply in a scrapyard, as they tend to be small, thin, fairly pwerfull, but not sap lots of energy! Are you on 6V or 12V, eitherway fans to suit both are available.
You can get a pump conversion for sidevalves I am sure I have seen them in the past!
Mello
Posted: Sun Nov 08, 2009 6:39 pm Post subject: |
Thanks for the advice folks.
I should add that the car is 6 volt and is not currently overheating, but I'm just pre-empting any issues, given the lack of a water pump!
I'll look into your suggestions and update once I've thought about it...  |
Posted: Sun Nov 08, 2009 6:53 pm Post subject: |
Another thought about fitting a water pump. Just fitting a pump might lead to overcooling, causing performance and fuel economy problems. Most thermo-syphon cooling systems did not include a thermostat. If a pump is added, a thermostat should be also. 'Stats which fitted in the top hose used to be available. Not sure if they are still obtainable. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
Posted: Sun Nov 08, 2009 8:30 pm Post subject: |
Jim, reading your post, I instantly thought of the top hose ones, I think they are still available, as have seen a few of them used on recent restorations, not sure who from though.
Greg
Posted: Sun Nov 08, 2009 9:57 pm Post subject: |
My 103e is totally standard and I have not had the slightest problem with overheating with the original thermosyphon system, even in traffic.
As previously mentioned, if all the passageways, two hoses and radiator are all clear, I would leave well alone.
That is, of course, you are going to keep the engine standard and not going in for time trials and hill climbing
Just be careful with that gas pedal, as we all know the 103e has 'Neck snapping' accelleration!
All the best,
Greg |
Posted: Mon Nov 09, 2009 2:21 am Post subject: |
My DLM1 with an E93A and full Aquaplane spec's has the aquaplane water pump fitted.
It has no fan fitted, not even to the front of the dynamo and the water temp. has never been critical
My only problem was fuel, heavy traffic the water temp never got too hot, and if it had been stationary for a while just thinking about touching the throttle it would die.
Park up for 15-20 minutes and away again.
The carbs would get too hot to touch, would idle with no problem.
I do have an electric fuel pump as well but will have try and isolate the carbs this rebuild.
Mind you now living out of London might help as well |
