highbeam
Joined: 18 Oct 2009 Posts: 12 Location: Melbourne - nr Essendon Airport
Posted: Mon Nov 09, 2009 8:30 am Post subject: RENRUT all brass tyre pump |
I had this pump over 50 years. I think I did use it many years ago.
Decided to overhaul it and make it work proper.
Can someone tell me, should there be 2 seals? I've shown you the main seal which needs changing. Should there be another small seal on the inner shaft?
I did find like half a seal with a lot of muck around it but not sure if it originally was a seal.
Thanks.
