rangerover125
Posted: Tue Dec 29, 2009 5:54 pm Post subject: 4 1/4 pcd 17 inch wheels and towhitch |
Well the Paldin rescue is on for Saturday. The only problem at the moment is finding a couple of 17 inch 4 1/4pcd 4 stud wheels to borrow to bring it over and I need to find a more modern hitch to fit on it. Its a rectangular one with 4 bolt fittings 1 3/4 inch across from bolt hole to bolt hole and 7 innch from fron bolt hole to rear. I may be able to get away with that, my sons static caravan has a hitch where the 2 front bolt holes are the right size so if totally stuck I'll use that and take it slowly. I'm just joining all my ratchet straps to go round the body as the panels are flapping in the air at present  |
