dwell from points gap
Timstopp
PostPosted: Fri Dec 11, 2009 10:50 am    Post subject: dwell from points gap Reply with quote
Forgive me if this is a stupid question, but is it possible to work out what the dwell angle should be from the points gap (even if it is in a "range" for a 4 cylinder car. I've guessed that the correct points gap should be 12 thou (from similar aged cars) but would like to check the actual dwell to elimainate dizzy wear.
Thanks
Tim
North Essex,UK - Morris 8 tourer 1936 - Jaguar x350
PostPosted: Fri Dec 11, 2009 11:09 am    Post subject: Reply with quote
50-60 for 4's and 34-39ยบ for 6's but all dizzies have their own optimum setting. Pre-war have a lower gap generally - increased dwell gives smaller gap
Rover P2
Morris Mini Traveller Mk2
Last edited by Phil - Nottingham on Fri Dec 11, 2009 11:43 pm; edited 1 time in total
PostPosted: Fri Dec 11, 2009 4:57 pm    Post subject: Reply with quote
My Morris 8 is 10 to 12 thou,
You can get away with a small gap with low revving engine's, smaller gap also give the coil the longest "charge" time, which if its 6v it needs!
PostPosted: Fri Dec 11, 2009 5:17 pm    Post subject: Reply with quote
Quite so and lathough my prewar Rover is a 6 cylinder with 12v electrics it will not run with well at all with a gap larger than 14 thou yet 1964 P5 3 Litre needs a 16 thou gap with its "high performance" HA12 coil. Its needs wide plug gaps too 29 thou but the prewar are 20thou
Rover P2
cswagon
PostPosted: Fri Dec 11, 2009 10:32 pm    Post subject: Reply with quote
Would anyone know the correct dwell angle for a Triumph 1500 FWD engine please ?
Thank you
Graham.
PostPosted: Fri Dec 11, 2009 11:05 pm    Post subject: Reply with quote
If it is a Lucas distributor it will be 60 degrees.
Timstopp
PostPosted: Sat Dec 12, 2009 7:26 pm    Post subject: Reply with quote
thanks, so much. Sounds like setting to a dwell of 60 deg is worth a go as I have a modern 12v coil fitted, which should set the points 10-12 thou (Ihope)
cswagon
PostPosted: Sat Dec 12, 2009 10:27 pm    Post subject: Reply with quote
Sorry Jim, serves me right for hijacking a thread.
Did you mean 60 degrees for my Triumph engine? And yes, I do have a Lucas distributor.
Thanks
Graham.
PostPosted: Sat Dec 12, 2009 11:18 pm    Post subject: Reply with quote
60 seems to high for postwar Lucas dizzies try 56/57
Rover P2
PostPosted: Sat Dec 12, 2009 11:49 pm    Post subject: Reply with quote
I would not presume to argue with the experts Phil. My Trade Autodata Manual gives 57 to 63 degrees for all 25D4 Lucas distributors I can find whatever they were fitted to including the Triumph in question. Hence 60 degrees nominal.
I have always set them as close to 60 as possible with excellent results Graham.
Timstopp
PostPosted: Sun Dec 13, 2009 12:16 am    Post subject: Reply with quote
Now I am confused, which of this applies to my question and which to 1960's triumphs!
Is 60 deg correct for 1930's lucas or 1960's??????
PostPosted: Sun Dec 13, 2009 12:57 am    Post subject: Reply with quote
Both - but always the higher for pre-war Lucas as had narrower gaps
Rover P2
Timstopp
PostPosted: Sun Dec 13, 2009 11:54 am    Post subject: Reply with quote
excellent! thank you very much!
Oops , just noticed my last post looked a bit grumpy, it wasn't meant to be I was just tired Embarassed
cswagon
PostPosted: Sun Dec 13, 2009 9:11 pm    Post subject: Reply with quote
Many thanks to you all for that, I shall try this setting this week hopefully.
And sorry Tim for jumping your thread and confusing matters.
Graham.
