6 Volt Car - Electric Fan?
Mello
PostPosted: Sat Mar 13, 2010 6:36 pm    Post subject: 6 Volt Car - Electric Fan? Reply with quote
I'm keen to insure against overheating this summer by fitting a Kenlowe fan or similar. However, my car is 6 volts. Is there any way I can run a 12 volt fan using my 6v system (i.e. with a transformer or whatever) or do I have to source a 6v fan?
Is there a supplier of suitable transformers in the UK that allows use of 12v accessories in a 6v car?
Thanks in anticipation of your suggestions/advice Smile
(in case you're wondering, it's a 1956 Ford Pop 103E)
traction39
PostPosted: Sat Mar 13, 2010 7:02 pm    Post subject: Reply with quote
I think Kenlowe make a 6volt version?
See http://www.kenlowe.co.uk/fans/consumers/fans05.html#
Alistair
Riley 9 Special 1932
PostPosted: Sat Mar 13, 2010 8:35 pm    Post subject: Reply with quote
There are plenty out there
Just type in "6 Volt radiator fan" in your search engine
I came up with 48,500 sites
Must be one closer to home for you
traction39
PostPosted: Sat Mar 13, 2010 8:49 pm    Post subject: Reply with quote
As a matter of interest, what car is it? Maybe look at the condition of the radiator and water pump to avoid overheating problems.
Alistair
PostPosted: Sun Mar 14, 2010 10:30 am    Post subject: Reply with quote
Coincidently I have been playing around with a 6v to 12v converter of my own design (my original training was electronic engineering) , so that 12v stuff like radio's , sat nav, phone chargers etc could be used in cars with 6v systems.
A transformer could be used to double the voltage if we were dealing with AC, DC however is a tad more complicated and needs a bit of electronics.
However if you can get a 6v fan this would be the best option as it avoids complication.
PostPosted: Mon Mar 15, 2010 1:45 pm    Post subject: Reply with quote
Kenlowe rate their products fron 5v tp 24 v I believe. i had the same issue last year and discussed it with them.Took their advice and all worked fine.
Paul
Mello
PostPosted: Wed Mar 17, 2010 7:50 pm    Post subject: Reply with quote
Thanks for the advice guys. Kenlowe ordered Smile
