allegro engine won't turn over properly
hillmanimpfan
PostPosted: Wed Apr 28, 2010 3:38 pm    Post subject: allegro engine won't turn over properly Reply with quote
my 1300 a-series won't turn over properly and starter motor can't turn it but it ok when turn by hand should put something down the bores to loose on it up but what oil
victor 101
PostPosted: Wed Apr 28, 2010 4:43 pm    Post subject: Reply with quote
If you can turn it by hand but not the starter I would check the starter circuit.
PostPosted: Wed Apr 28, 2010 6:55 pm    Post subject: Reply with quote
Yup check all starter connections as victor 101 says, including the main engine->body earth strap, and the solenoid (is it separate on those???).
hillmanimpfan
PostPosted: Wed Apr 28, 2010 8:57 pm    Post subject: electrically ok Reply with quote
starter circuit ok and turns electrically but not the strenght to turn the engine the battery is ok as tested it on another car turns it fine engine been unused for few years and changed the oil and filter to make shore
PostPosted: Wed Apr 28, 2010 11:52 pm    Post subject: Reply with quote
Sound like you might have some corroded conections.
You could get a good reading with a meter but if there is corrosion the power won't get through enough under load
Disconect all conections, live and earth, clean all surfaces and reconect.
I fit shake proof star washer wherever there is a conection, they bite and help.
Roger
hillmanimpfan
PostPosted: Thu Apr 29, 2010 8:18 pm    Post subject: Reply with quote
done this think the engine stiff what can put down the bores to looses them up
Kelsham
PostPosted: Fri Apr 30, 2010 2:23 pm    Post subject: oil bores Reply with quote
I sugges that you remove all the plugs and use a small amount of diesel down the bores.
With the plugs removed you should be able to turn the engine over either by use of a spanner on the front pulley nut, or put the car in top gear and use a wheel to turn the engine, after jacking it off the floor.
If the engine will not move leave the diesel to soak the rings etc. overnight.
Of course you will be doing an oil change before running the engine wont you?
hillmanimpfan
PostPosted: Fri Apr 30, 2010 2:56 pm    Post subject: Reply with quote
would made any differences as it has a 1100 head on it not 1300 thanks for tip
bob2
PostPosted: Fri Apr 30, 2010 3:31 pm    Post subject: Reply with quote
i know that a 1275 head(small valves) will fit on a smaller block but the valves will JUST clear the block so I should think that the opposite way round it should not be a problem!!
hillmanimpfan
PostPosted: Fri Apr 30, 2010 5:53 pm    Post subject: Reply with quote
haven't got any diesel and my local garage as gone i put some clean engine oil and now turn over every few minutes seem to be looseing up thanks everyone for help
