hillmanimpfan
Posted: Wed Apr 28, 2010 3:38 pm Post subject: allegro engine won't turn over properly |
my 1300 a-series won't turn over properly and starter motor can't turn it but it ok when turn by hand should put something down the bores to loose on it up but what oil |
victor 101
Posted: Wed Apr 28, 2010 4:43 pm Post subject: |
If you can turn it by hand but not the starter I would check the starter circuit. |
hillmanimpfan
Posted: Wed Apr 28, 2010 8:57 pm Post subject: electrically ok |
starter circuit ok and turns electrically but not the strenght to turn the engine the battery is ok as tested it on another car turns it fine engine been unused for few years and changed the oil and filter to make shore |
Posted: Wed Apr 28, 2010 11:52 pm Post subject: |
Sound like you might have some corroded conections.
You could get a good reading with a meter but if there is corrosion the power won't get through enough under load
Disconect all conections, live and earth, clean all surfaces and reconect.
I fit shake proof star washer wherever there is a conection, they bite and help.
Roger |
hillmanimpfan
Posted: Thu Apr 29, 2010 8:18 pm Post subject: |
done this think the engine stiff what can put down the bores to looses them up |
Kelsham
Posted: Fri Apr 30, 2010 2:23 pm Post subject: oil bores |
I sugges that you remove all the plugs and use a small amount of diesel down the bores.
With the plugs removed you should be able to turn the engine over either by use of a spanner on the front pulley nut, or put the car in top gear and use a wheel to turn the engine, after jacking it off the floor.
If the engine will not move leave the diesel to soak the rings etc. overnight.
Of course you will be doing an oil change before running the engine wont you? |
hillmanimpfan
Posted: Fri Apr 30, 2010 2:56 pm Post subject: |
would made any differences as it has a 1100 head on it not 1300 thanks for tip |
bob2
Posted: Fri Apr 30, 2010 3:31 pm Post subject: |
i know that a 1275 head(small valves) will fit on a smaller block but the valves will JUST clear the block so I should think that the opposite way round it should not be a problem!! |
hillmanimpfan
Posted: Fri Apr 30, 2010 5:53 pm Post subject: |
haven't got any diesel and my local garage as gone i put some clean engine oil and now turn over every few minutes seem to be looseing up thanks everyone for help |
