Posted: Mon Apr 19, 2010 5:45 pm Post subject: Most unpleasant jobs |
Doing the brakes on the Standard reminded me of how much I dislike fiddling with rusty old wheel cylinders, battling with tiny brake adjusters that are moments away from rounding off, and brake fluid on the skin.
The only worse jobs that spring to mind are lying underneath a car and trying to weld something up, and battling with corroded exhaust manifold nuts. By comparison, oil changes and Waxoyl sessions are bliss!
Posted: Mon Apr 19, 2010 7:45 pm Post subject: |
I agree 100% - I thought I only had these jobs on Rover/Land Rover and Mini - problem is they keep on coming round again no matter what I try to do to make it easier next time
The brake adjusters are huge in Rovers/Land Rovers but still can seize up along with wheel cylinders - exhaust bolts even with brass nuts still give trouble as do spring shackle bolts.
Replacing a blown bulb often results in changing the whole lamp unit too  _________________ Rover P2
Posted: Mon Apr 19, 2010 8:52 pm Post subject: |
99% of jobs that require working within the engine bay of modern cars. You have to strip half the ancillaries to get into anything _________________ ROVER
One of Britain's Fine Cars |
Posted: Mon Apr 19, 2010 9:15 pm Post subject: |
Changing the points and condenser on an A35 - there is absolutely no access and it is actually easier to take the blasted distributor out to do jobs on it
Likewise on a 2CV - you have to remove the fan to get anywhere near.
As above - Vauxhall Victor wheel cylinder adjusters are very prone to the adjusters seizing and rounding.
Mk3 Fiesta rear wheel cylinders are held on with an allen bolt that readily corrodes and rounds, again there is no access and the things are incredibly difficult to get off. And when you do get them on, you've got the self adjusting rear brake mechanism to contend with - that's a nightmare.
Any car with a spin on filter that is hidden away behind the engine with no access to remove it, although cartridge type filters can be just as bad, firstly getting a sleeveful of old oil, followed by several minutes swearing at the rubber sealing ring which refuses to engage in the slot. _________________ Richard Hughes |
Posted: Mon Apr 19, 2010 11:36 pm Post subject: |
Richard H wrote: | Changing the points and condenser on an A35 - there is absolutely no access and it is actually easier to take the blasted distributor out to do jobs on it
Try that on a Mk1 Fiesta. it is down behind the engine and exhaust manifold. _________________ Bristols should always come in pairs.
bob2
Posted: Tue Apr 20, 2010 7:42 am Post subject: |
I too hate doing the brakes on all cars especially the mini ones, hate the circlip to hold the wheel cylinder in place, it always breaks in two whatever I try to slot it in place!!!
unfortunately on the hunter's wheel cylinders I have the same retention circlip to struggle with!!!
michael1703
Posted: Tue Apr 20, 2010 8:11 am Post subject: |
working on anything vaguely modern
its soul destroyingly dull and annoyingly fiddly |
Rusty
Joined: 10 Feb 2009 Posts: 272 Location: Bunbury, Western Australia
Posted: Fri Apr 23, 2010 11:12 am Post subject: |
Replacing Mini by pass hoses is what gives me a pain !!!!!!
You need to be a blinkin midget !!  |
michael1703
Posted: Tue May 04, 2010 8:55 pm Post subject: |
air cooled volkswagens  |
P3steve
Posted: Wed May 05, 2010 7:16 am Post subject: |
(air cooled volkswagens) Thank goodness I thought I was the only one |
michael1703
Posted: Wed May 05, 2010 7:35 am Post subject: |
why are they so overrated and sought after?
people are paying £17k-£22k for bad handling,slow,clattery old campers
for that money i would buy an e type,jensen 541,mustang,charger,mk11,or something that justifies the ependiture |
Salopian
Posted: Wed May 05, 2010 11:12 am Post subject: |
Well that makes at least 3 of us here in agreement!
Off topic I suppose but I knew a chap who was driving a VW microbus which had a low speed head on with a lorry (not the VW mans fault). Lost a leg - little or no front protection for them rather like those Bedford Rascal type vans. _________________ Jonathan Butler
Posted: Wed May 05, 2010 12:23 pm Post subject: |
Least favourite job ?. Fitting those fiddly horseshoe clips that hold the rear wheel cylinders on my mk1 transit.
Jobs that even the professionals have aggro with,fitting the screen in a fairway taxi.Flat and small so it looks like a doddle,I busted one trying to refit it into a new surround.I called in a local company who my local really struggled but still cracked one trying to fit it,I then heard of one company that cracked ten of them before getting one to fit. _________________ Thirty years selling imperial hand tools for old machinery(Now happily retired). |
michael1703
Posted: Wed May 05, 2010 7:03 pm Post subject: |
Salopian wrote: | Well that makes at least 3 of us here in agreement!
Off topic I suppose but I knew a chap who was driving a VW microbus which had a low speed head on with a lorry (not the VW mans fault). Lost a leg - little or no front protection for them rather like those Bedford Rascal type vans. |
i had a head on in my ford thames 400e, luckily it was slow speed, but that could have cost me a limb at a greater speed, i got a dig from the throttle pedal when it folded round my boot!
(DISCLAIMER: not that i am making a dig at my customers' choices of transport and i'm only too glad to fix more nazi wagons ) |
Nic Jarman
Posted: Thu May 06, 2010 3:59 pm Post subject: |
Ballancing SU carbs. Not a horrible job in itself but you know they will be back out of ballance in a week.  _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
