Bayliss Thomas
Posted: Thu Jun 10, 2010 7:39 pm Post subject: Screeching brake problem |
| The drum brakes on my car have always made an heck of an din screeching, its now very embarrassing. I was told that I should wrap an length of brake hose around the external perimeter of the drum and secure / tighten and clamp. This I am assured will cure the problem, has anyone tried this or have other remedies. Thanks. |
michael1703
Posted: Thu Jun 10, 2010 10:09 pm Post subject: |
| constant screeching or screeching on moderate/heavy braking? |
Fluffle-Valve
Posted: Thu Jun 10, 2010 11:15 pm Post subject: |
Clean the brake dust out of the drums and use some heavy gritted sand paper to score the inside of the drum and take the sheen off the shoes...
Worked on my Series III Land Rover... _________________
Bayliss Thomas
Posted: Fri Jun 11, 2010 12:52 pm Post subject: |
Thank you for replies, the brake linings are new and the drum are clean, but I will put some sandpaper over the linings to rough them up a little.
The screeching is as soon as I start braking and the heavier I brake the louder it gets and it is really very loud indeed.  |
Posted: Fri Jun 11, 2010 1:14 pm Post subject: |
Screaching can be caused by movement in the operating mechanism or securing points. Maybe even the wheel bearings. Any play will allow the shoes or drum to vibrate. This is just about one of the most annoying problems to solve as the vibration/sound can travel through parts and sound like it is coming from somewhere else. Good luck. _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
poodge
Posted: Sat Jun 12, 2010 5:54 am Post subject: |
| Local lore always suggested the ends of the linings to be beveled at about 45 degrees,to combat said problem.Don't know if it works though. |
Brian M
Posted: Sat Jun 12, 2010 7:34 am Post subject: |
An old mechanic told me many years ago to put a smear of Copper Grease on any points where metal rests on metal within the braking system. I have been doing this ever since and have only heard a squeak when the grease has worn through.
On discs I put it on the back of the pads where the caliper piston pushes and on the tips of the pads where they rest in the "cradle".
Just did the drums on the back of the Volvo, and put it on the ends of the shoes, and on the back plate where the shoes touch four raised areas. _________________ Brian
Posted: Sat Jun 12, 2010 11:17 am Post subject: |
A chamfer on the leading edge helps to have a smooth progressive brake. If you have a look at the Talbot thread you will see the copper grease on all moving parts in the brakes. However the brakes do squeal slightly They will probably bed in. Always put a dab on the back of disc pads. WARNING new old stock may well contain asbestos. _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
lowdrag
Posted: Mon Jun 14, 2010 9:00 am Post subject: |
Reminds me of the time when we a chap on tour complained of squealing discs. He thought he'd cure the problem by greasing the disc..........
No, a true one, not an old wive's tale either.  |
Posted: Mon Jun 14, 2010 9:13 am Post subject: |
| lowdrag wrote: | Reminds me of the time when we a chap on tour complained of squealing discs. He thought he'd cure the problem by greasing the disc..........
Yes, so silly. We all know it would just burn off!
Posted: Mon Jun 14, 2010 12:31 pm Post subject: |
| peter scott wrote: | | lowdrag wrote: | Reminds me of the time when we a chap on tour complained of squealing discs. He thought he'd cure the problem by greasing the disc..........
Peter  |
Is that before or after he hits the car in front? Crash and burn, best way to go.  _________________ 1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush |
Posted: Mon Jun 14, 2010 5:26 pm Post subject: |
| Brian M wrote: | | An old mechanic told me many years ago to put a smear of Copper Grease on any points where metal rests on metal within the braking system. |
As another old mechanic, I think a smear of zinc base gease or alternatively copper grease SHOULD be applied to every contact surface within the brake drum (except of course the linings, which must not be contaminated in any way).
During the course of the life of the linings (and during adjustment) the shoes are constantly re- centreing themselves to keep in maximum contact with the drum. Lack of suitable lubrication will lead to a fall of in performance and uneven wear along the length of the lining.
Somewhere on this Forum there is quite a lot of posting about strapping of various kinds around brake drums to alter the vibration frequency which causes the noise. It used to be fairly common 'wen I wer a lad'.
Bayliss Thomas
Posted: Wed Jul 07, 2010 10:06 pm Post subject: |
| Thanks for all the tips, I still haven't got around to my attempt to banish the noise but will first try out the trick of 'strapping' an band around the drum. |
WLC4EVA Guest
Posted: Sun Jul 18, 2010 6:34 pm Post subject: |
You say your drums were clean Thomas.
Did you break the glaze?
If not, here's the poor man's method,
1) bolt the drum backwards onto a driven axle hub.
2) with the engine ticking over in first gear
3) apply sandpaper to friction face of rotating drum.
4) repeat for other 3 drums.
5) count fingers, actually, I think it feels a lot more dangerous that it is.
Don't do it with permanent all-wheel drive unless all your wheels are off the ground.
A prudent man gets his drums skimmed at a machine shop before he fits new linings.
Kind Regards, WLC
