Window garnish pieces needed
Russ B
PostPosted: Wed Nov 02, 2005 11:05 pm    Post subject: Window garnish pieces needed Reply with quote
Hi all, I am in Calgary Alberta Canada and looking for window garnish pieces for inside around the door windows. They do not have to be perfect! My truck is far from stock as parts are so few and far between over here. I have done extensive body mods and chassis work. I know how some feel they should be left original and as close to stock as possible. At least it aint CRUSHED.
Any help locating these parts would be greatly appreciated!
Russ
PostPosted: Fri Nov 04, 2005 9:05 am    Post subject: Reply with quote
It might be worth contacing some of the Canadian register members on the e83w site itself, they may be able to help with parts
rgds
Russ B
PostPosted: Fri Nov 04, 2005 9:36 pm    Post subject: tried Reply with quote
I have tried a couple with no response
Russ
rustyreks
PostPosted: Mon Apr 30, 2007 10:13 am    Post subject: window parts Reply with quote
Russ came across site looked promising sounds like he might have your parts rustyreks
rustyreks
PostPosted: Mon Apr 30, 2007 10:14 am    Post subject: window parts Reply with quote
Russ came across this american site looked promising sounds like he might have your parts http://www.angliaobsolete.com/page1.html rustyreks
rustyreks
PostPosted: Sun Jul 25, 2010 1:19 pm    Post subject: window garnishs Reply with quote
Russ did you ever get your window frames etc for your e83w? rustyreks
rustyreks
PostPosted: Thu Jul 29, 2010 10:15 am    Post subject: window garnishs Reply with quote
Russ if you havent found any i have some i am in new zealand rustyreks
