Stripping a car
Car-Nut
PostPosted: Sat Aug 14, 2010 7:01 pm    Post subject: Stripping a car Reply with quote
With a new project on the horizon, I will no doubt have some bodywork to strip down to bare metal which ever car I buy.
As far as I'm aware there are 3 ways to strip paint but I'm not an expert there may be more:
1) Paint Stripper
2) Sanding Disks & Wire Brushes etc
3) Heat
Fors and against for all I'd love to here, plus any tips Wink
Or are there are any better ways Question
Car-Nut
'62 S1 Jaguar E-Type 3.8 FHC
'70 420G - 13th from last RHD
'70 420G - 17th from last RHD
PostPosted: Sat Aug 14, 2010 7:06 pm    Post subject: Reply with quote
You'll probably end up using all of the above, and maybe more. With a bit of luck the car won't be so bad, and you'll not necessarily need to bare-metal it all. The problem with stripping back to bare metal is that it starts to rust quite quickly, so you need to plan for putting some paint - even if only primer in the short term - on it as soon as possible.
michael1703
PostPosted: Sat Aug 14, 2010 7:27 pm    Post subject: Reply with quote
get it shot blasted and primed, its a big car.. £300 ish at a guess
pryantcc
PostPosted: Sun Aug 15, 2010 10:03 pm    Post subject: Reply with quote
I have used surface Processing in Dudley to clean my chassis. The process is fantastic, and for the time and effort it saves, is well worth the money in my opinion. They will also e-coat the car which is a very robust and thorough coating that will protect your investment for a very long time.
the reason I decided on this process was because I couldn't think of any possible way to achieve absolute corrosion and contaminate removal from the inside of the box-secitons of chassis. The joy of the process is that it is performed by liquids which can get absolutely everywhere!
Be prepared for it to expose holes you never knew were there though!!
PostPosted: Mon Aug 16, 2010 11:25 am    Post subject: Reply with quote
Please read UKdave2002's restoration of his Morris 8 series E.
http://www.oldclassiccar.co.uk/forum/phpbb/phpBB2/viewtopic.php?t=5790&postdays=0&postorder=asc&start=15
If you haven't then you have missed really good posting.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
