dave 35
Posted: Sun Aug 22, 2010 3:28 pm Post subject: piston rings |
hi, I wonder if anyone can help me. I am restoring a 1935 Hillman 16 in which the engine has been rebored to plus 60. I wonder if anyone can tell me what the piston ring gap should be when the ring is sitting in the bore. I have no technical information on this engine at all. Has anyone got any literature on a 1935 Hillman 16 which might help me. Any help would be very much appreciated.
regards Dave 35 |
Salopian
Posted: Sun Aug 22, 2010 9:19 pm Post subject: |
For water cooled engine compression rings I was always told 4-5 thou times the bore in inches so 3 inch bore 15 thou etc. As it has been rebored I assume need not consider top ridge and barrelling etc.
Oil ring a little less is permissable say 12 thou.
Its always worked for me but its your risk!
Good luck. _________________ Jonathan Butler
dave 35
Posted: Mon Aug 23, 2010 12:04 pm Post subject: |
| Thanks Salopian i have today filed the rings and fitted the pistons so far so good regards dave35 |
Posted: Mon Aug 23, 2010 2:34 pm Post subject: |
Hi Dave,
Probably not critical but the post war 1256cc side valve Hillman workshop manual quotes 6 to 10 thou for the ring gaps. It has a bore of 2.563".
Posted: Mon Aug 23, 2010 9:40 pm Post subject: |
I was taught 3 to 4 thou/inch for water cooled engines and 4 to 5 thou/inch for air cooled including oil control rings.
Always worked for me. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
