Midget indicators
Finch661
PostPosted: Mon Aug 30, 2010 10:19 am    Post subject: Midget indicators Reply with quote
i have an odd indicator at the problem. when i signal right the indicators flash really quickly (so quickly that the tell tale doesnt even light up), both right hand bulbs work. The weird thing is that if the steering wheel is pulled out a bit (there is slight vertical movement) the problem goes away....
whats going on?
cheers Smile
1985 Mini Mayfare (1275)
1976 Mg Midget 1500
Uncle Alec
PostPosted: Mon Aug 30, 2010 11:22 am    Post subject: Reply with quote
Something drastic. The current is passing to earth with not much impedence. Get it checked out right away; disaster looms (forgive the pun).
Finch661
PostPosted: Mon Aug 30, 2010 12:00 pm    Post subject: Reply with quote
cheers for the reply. i am guessing it must be something in the stalks because of the wheel causing it?
1976 Mg Midget 1500
Uncle Alec
PostPosted: Mon Aug 30, 2010 12:04 pm    Post subject: Reply with quote
Midget expert required, but it does sound that way.
Finch661
PostPosted: Mon Aug 30, 2010 12:10 pm    Post subject: Reply with quote
i will take the cowling and the wheel off, and see whats going on!
1976 Mg Midget 1500
victor 101
PostPosted: Mon Aug 30, 2010 2:49 pm    Post subject: Reply with quote
You shouldnt need to take the wheel off for your indicator problem but while the cowlings off try and find out why your column has so much play in it.
Finch661
PostPosted: Mon Aug 30, 2010 3:27 pm    Post subject: Reply with quote
ok will do that. i know its odd, its always been like that. will have a good look around!
1976 Mg Midget 1500
PostPosted: Mon Aug 30, 2010 3:56 pm    Post subject: Reply with quote
If the column is a rigid one (ie not adjustable for length) then any movement along the column axis can only be at the ends.
Top end, movement on the splines, oir bottom end could be excess float in the box or R&P; or the box/R&P is not fixed down securely.
PostPosted: Mon Aug 30, 2010 7:39 pm    Post subject: Reply with quote
I have just had a look at steering column and there is no vertical movement and I have about 1mm in and out movement. The steering shaft goes into the fixed outer at the indicator stick so there should be no chance of the wires chafing here. I can only think that a wire is caught in the upper mount and a fault like this should be sorted ASAP.
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Finch661
PostPosted: Mon Aug 30, 2010 9:18 pm    Post subject: Reply with quote
aye you might be right. i also noticed that my indicator cancellers dont work either. and the right indicator problem seems to be alos happen when i turn the wheel right as well. def something is catching
1976 Mg Midget 1500
PostPosted: Mon Aug 30, 2010 9:39 pm    Post subject: Reply with quote
My cancellers dont work either. Not one to worry about.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Finch661
PostPosted: Mon Aug 30, 2010 9:46 pm    Post subject: Reply with quote
yeah, but they did work. its the first time my midget has been out for a few months. sigh my wee midget is getting old Sad
1976 Mg Midget 1500
PostPosted: Mon Aug 30, 2010 10:06 pm    Post subject: Reply with quote
Get your Midget out and drive it, OK fix it first, my Midget has done 10,000 miles in the last year and it is driving just great. I slide into the seat, slip on the shades, nudge it into 1st and smile. Cool
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Finch661
PostPosted: Mon Aug 30, 2010 10:18 pm    Post subject: Reply with quote
my midget has done 15000 miles in 34 years, poor wee car
1976 Mg Midget 1500
PostPosted: Mon Aug 30, 2010 10:34 pm    Post subject: Reply with quote
Can I adopt your Midget?
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
