victor 101
Posted: Sun Sep 12, 2010 8:09 pm Post subject: Weld through primer |
Anyone used weld through primer, were you happy with it, what make was it?. I read somewhere that you cant actually weld through it which makes a mockery of the name, is this true?.
Grateful for any input. |
Fluffle-Valve
Posted: Sun Sep 12, 2010 8:17 pm Post subject: |
I've never heard of Weld Through Primer. I've always welded on clean surface's.. _________________
michael1703
P3steve
Posted: Mon Sep 13, 2010 7:07 am Post subject: |
I've used with both a spot welder and a mig and have had no trouble welding through it and as michael1703 says it gives you some peace of mind knowing there is at least something covering the metal which you may no longer be able to get to. |
victor 101
Posted: Mon Sep 13, 2010 1:55 pm Post subject: |
Thanks for the input, I will order some from Frost's, Regards Rod. |
StoneRoad
Posted: Tue Sep 14, 2010 8:46 pm Post subject: |
bit late on this one as I managed not to have power to the laptop!
However I can confirm that the stuff exists, and you can weld with it on the metal.
The place were we have our shot/bead blasting done, if you want, will spray the metal immediately in comes out with a weldable primer, which we have welded through when repairs were required. (some non-structural parts on the two coal waggons we rebuilt some months back).
Unfortunately, I can't remember the product name!
Sorry I can't help further.
StoneRoad _________________ Saluton. mi estas fervojistino, kaj vi?
visit http://www.ipernity.com/doc/312383/album
to see what has been done! Perhaps we can do something for you? |
