Craig
Joined: 19 Mar 2008 Posts: 80 Location: Frome, Somerset
Posted: Wed Oct 20, 2010 1:43 pm Post subject: Trafficator hole blanking plates |
Made from 18 gauge mild steel and designed to fit in the original trafficator hole of the Ford Pop/Anglia.
These may fit other cars, you will need to check the measurements.
214mm long
10mm wide, 12mm in the thicker part
£5.50 posted to you....
