websnail
Posted: Wed Nov 03, 2010 12:34 am Post subject: Rivnut tool |
Hi boys and girls.
I need a rivnut tool. Has anybody made one and if so what form did it take ( no reason to re-invent the wheel). I need to fit some (5 or 6 off) 5/16" or 8mm rivnuts and I don't want to buy one to fix such a small number.
Thanks in advance  |
Posted: Wed Nov 03, 2010 12:52 am Post subject: |
This system can work. Using a hi-tens capscrew, as per link, may be safest way. A good arrangement of washers, or even make one, with a coating of grease.
http://www.m-gineering.nl/tipsoldg.htm |
Posted: Wed Nov 03, 2010 8:41 am Post subject: |
If you were local you could borrow one from me, maybe a member closer to you has one they can lend you?
Posted: Wed Nov 03, 2010 8:47 am Post subject: |
| peterwpg wrote: | This system can work. Using a hi-tens capscrew, as per link, may be safest way. A good arrangement of washers, or even make one, with a coating of grease.
the link shows how to repack a sealed bearing, but it tells to repack as much grease as will go in, this is not strictly true for the bearings that are "Sealed" is it?
They need less grease than one may think. Overgreasing will cause the seals to pop and the bearings to overheat?
Well they did to the ones my friend tried on a agricultural machine.
Anyway I am going off topic!
websnail
Posted: Wed Nov 03, 2010 10:56 pm Post subject: |
I'm sure I'll be able to make something work along those lines. Thanks.  |
