Making up fuel pipes?
PostPosted: Sun Sep 20, 2020 2:08 pm    Post subject: Making up fuel pipes? Reply with quote
I am looking to make up some fuel pipes for one of the lorries, I have plenty of Copper pipe left from doing the brakes so plan to use that.
I just need to find someone who can supply the right fittings for the AC fuel pump and the Solex carb.
alanb
PostPosted: Sun Sep 20, 2020 9:31 pm    Post subject: Reply with quote
Have you tried Burlen they are usually very helpful.
old tourer
Morris 8 two seater
PostPosted: Mon Sep 21, 2020 8:30 am    Post subject: Reply with quote
Vintage Supplies will probably stock the fittings required:
https://www.vintagecarparts.co.uk/categories/vintage-car-parts-taps-pipe-and-fittings-fittings
You will need to know the fittings size on the carb & pump, and if making up compression fittings the pipe will clearly need to be the correct size for the fittings.
PostPosted: Mon Sep 21, 2020 12:54 pm    Post subject: Reply with quote
Never heard of Burlen before so have checked out the website and I have ordered from Vintagecarparts before so I am going to check the sizes when I next go down the yard before making any purchases.
PostPosted: Mon Sep 21, 2020 1:22 pm    Post subject: Reply with quote
Burlen hold the status of SU experts now...[in place of SU]....been at it a loooong time too...
