FAB Cruiser
Posted: Sat Jul 05, 2008 1:08 pm Post subject: Alarm wiring |
I'm putting an alarm in my car. A 57 Zephyr converted to negative earth.
It has a pair of wires for 'starter immobilisation'. This circuit will be closed when the alarm is off and open when the alarm in on to stop the started motor working. The two wires are quite heavy duty.
Should I use them to interrupt:
a) The cable from the solenoid to the starter
b) The cable from the ignition switch to the Solenoid
c) The cable from the battery to the starter solenoid
d) The cable from starter solenoid to the voltage regulator
Probably more dumb questions to follow!!
Thanks
David |
Posted: Sat Jul 05, 2008 2:04 pm Post subject: |
My vote goes for b.
Peter |
wrinx
Posted: Sat Jul 05, 2008 3:12 pm Post subject: |
I'd say B as well....
Mine had what looks like a DIY pull switch immobiliser which isolates the coil and fuel pump Car will still turn over but not run...which is useful at times. When it's not been run for a while I'm able to crank it over to get some oil pressure prior to starting
wrinx _________________ www.alfaromeo155.co.uk | www.alfamatta.co.uk
Greeney in France
Posted: Sat Jul 05, 2008 7:39 pm Post subject: |
I tend to use the Low tension circuit as immobiliser, the wire from the dissy to the coil _________________ www.OldFrenchCars.com
Greg
Posted: Tue Jul 29, 2008 11:39 pm Post subject: |
| I would cut 'b' or as Greeney says the L.T side of the Coil as the older cars usually draw more current than the modern stuff. Most good Immobiliser relays are only rated at 30 amps! |
