Austin ten 1935 lichfield Voltage regulator
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Electrical
Wardy0589
PostPosted: Tue Aug 12, 2008 5:55 pm    Post subject: Austin ten 1935 lichfield Voltage regulator Reply with quote
Hi can anyone help, I'm having trouble with the voltage regulator on my Austin ten. Either its off (no charge at all) or charges uncontrollably up to 20amps on the ammeter, no cut off
Its a new/replacement regulator, the wiring is correct (I think!- there were'nt as many terminals on this one), the dynamo charges OK. Is it anything to do do with the two screws on the top- tried adjusting, nothing happens.
Thanks, Chris
PostPosted: Tue Aug 12, 2008 6:45 pm    Post subject: Reply with quote
Welcome to the forum, I'll move this to the Restoration (Electical) section if thats ok
PostPosted: Tue Aug 12, 2008 7:40 pm    Post subject: Reply with quote
What type is it. cars then as now used stock electrical parts that fitted to a lot of other makes of the time.
They are reliable, simple and can be adjusted and repaired but only if you follow a set procedure - random tinkerings will ruin it and the dynamo/wiring
Phil
PostPosted: Tue Aug 12, 2008 8:26 pm    Post subject: Reply with quote
Hi Chris,
One possible explanation is that the shunt coil in the regulator is open circuit. It is connected between the D and E terminals. Having said that so does the shunt coil in the cut-out so you would need to disconnect one from the E terminal in order to determine whether it's O/C or not.
PostPosted: Wed Aug 27, 2008 10:52 am    Post subject: Reply with quote
Hi Chris
Is it a 2 or 3 brush dynamo? ( if you don't know can you read they dynamo model number?) and what control box / regulator are you using? you may have a later control box trying to regulate a 3 brush dynamo. Some where on the forum I did post how to set control box's up.
Post new topic   Reply to topic    Classic cars forum & vehicle restoration. Forum Index -> Restoration - Advice - Electrical All times are GMT + 1 Hour
Halfords
