AlpineAndy
Posted: Tue Sep 10, 2013 8:16 pm Post subject: Sunbeam Alpine anti-roll bar |
Hi,
Well this is my first post so please bear with me.
I have a 1964 Sunbeam Alpine and have rebuilt the from suspension to replace the bushes, and dampers.
I have it all together with the exception of the anti-roll bar. The car is presently jacked up and the suspension is not under tesnsion. However try as I might I cannot get the antiroll bar located in order to get the bolts in.
Does anyone have any tricks up their sleeve?
Thanks,
Andy |
Posted: Wed Sep 11, 2013 10:15 am Post subject: |
Hi Andy,
Welcome to the forum.
If you jack the car up on the centre of the cross member then you should be able to set the wishbones to any angle and find a neutral position for the roll bar just by raising or lowering the jack. If the wishbones need to go higher then jack it at one side only and under wishbone.
http://www.oldclassiccar.co.uk/sunbeam.htm
HTH
