Stuart2u
Posted: Mon May 20, 2013 9:48 am Post subject: Morris 8 E Recondition engine....differences |
I have acquired a fully reconditioned Morris 8 E engine from a local engineer and Morris spares man. Have seen his work in progress on the engine and witnessed it running on his test rig. Now waiting for winter to fit it......However, I have noticed some differences in the engine to the one in the car. Its a bolted on casing to the engine block above the bottom water intake. (picture attached). He did mention that it was a later block which would have been in the first Morris Minors with the side valve engine.
I just don't understand the purpose of the casing. Nothing goes into or out of it!!!!!?????
Also on the other side of the block is what I take to be the location for an external oil filter........is this correct? If so is there a kit available still and would it be worth fitting. From what I recall the sump located 'oil filter' is fitted to the internal pump pick up. (see picture)
Stuart
[img] [/img]
[img] [/img]
(edit RJ: fix for horizontal scrolling) |
Joined: 23 Nov 2007 Posts: 4282 Location: South Cheshire
Posted: Mon May 20, 2013 10:02 am Post subject: |
Hi Stuart
What you have is a later block, the bolt on casting provides better water flow & cooling, it was first used when the engines were used in tanks, tractors and boats, but carried on to the post war minor. If you take it off, you will see where Morris have drilled the block to allow the water to circulate into the casting.
You have correctly identified the oil take off for an external filter, people have fitted them to 8's, but they need modification to clear the axle.
Pic below is my Tank engine, with external oil filter , next to a standard block.
Stuart2u
Posted: Tue May 21, 2013 11:37 am Post subject: |
Dave. Thanks once more for your help......
Stuart |
