Exhaust valve pitting.
arossco
PostPosted: Mon May 20, 2013 3:37 pm    Post subject: Exhaust valve pitting. Reply with quote
Hi -
I'm overhauling my 1956 Cresta engine, and have noticed some pitting on the exhaust valve stems, though the valve seat area seems to be Ok.
Should I replace the valves which have this kind of pitting ?
Ross
[/url]
PostPosted: Mon May 20, 2013 6:27 pm    Post subject: Reply with quote
Hi Ross,
I don't think the pitting will make your stems any more likely to fracture than the collett grooves and I don't think they will noticably affect the rate of oil passage down the stems so my advice would be just to fit them.
PostPosted: Mon May 20, 2013 7:34 pm    Post subject: Reply with quote
Acid/moisture in old oil but probably will be OK
Rover P2
Morris Mini Traveller Mk2
arossco
PostPosted: Mon May 20, 2013 8:39 pm    Post subject: Reply with quote
Many thanks Peter and Phil - I'll put these valves back into service !
Ross
