1930 Morris Cowley
PostPosted: Fri May 17, 2013 7:47 pm    Post subject: 1930 Morris Cowley Reply with quote
I've just taken delivery of a new addition to the family:
a 1930 Morris Cowley fixed-head saloon, one of the last with 'improved' steering and braking; my initial impressions are what the h**l were they like before the changes : the steering is incredibly heavy, and the brakes are about up to Austin Seven standards on a bad day Shocked
Looks like there's a bit of fettling due Rolling Eyes
PostPosted: Fri May 17, 2013 10:55 pm    Post subject: Reply with quote
Properly smart, it'll be interesting to see how you get on with it - centenary year and all for Morris isn't it?
NONORT
PostPosted: Tue Jun 04, 2013 9:51 am    Post subject: Reply with quote
Hi just a thought. The Cowley that I drive has reasonable steering. It is on beaded edge tire's ie narrow ones and they are run at 50 psi. Just wondered if a bit more puff in the tire's would help. The brakes should be reasonable given the age of the car. If not try roughing up the brake linings and glaze bust the drums linings tend to got hard and glaze up if not used heavily now and again. the front and rear axle seal on a Cowley is a felt ring which if the car has had to much grease added to the bearing will get past the seal and into the drums both front and back. Nice clean car though hope to see you around at one of the BNMC club events. Well worth joining for the spare parts service alone.
PostPosted: Tue Jun 04, 2013 7:58 pm    Post subject: Reply with quote
Thanks, Nonort, for the feedback. I am comparing it with the 1922 Star which I ran until recently: like your Cowley on beaded edge tyres running at 70psi; that had beautifully light steering. The Cowley, on the other hand, is on 475x19 well based, and according to the official handbook, should be run on 24psi front, 28psi rear. Now that sounds very soft to me for a car weighing presumably around 20cwt, so I have upped them to 30/34 for starters: a slight improvement, but nothing like my memory of my old Austin 12/4 from many years ago - but then I had never experienced power steering back then Very Happy ...
As for the brakes, in terms of stopping power they are not too bad, but the pedal has a very long travel with a spongy feel, which is not what I would expect on a Vintage car any comments?
NONORT
PostPosted: Wed Jun 05, 2013 9:28 am    Post subject: Reply with quote
The only thing that springs to mind is. if the shoes are well worn the cam action of the cams becomes less effective. It may pay to check how far the operating arm goes back if you disconnect a pull rod. An old bodge of years gone bye is to make shims to wrap around the ends of the brake shoe to effectively jack it out closer to the drum. either that or reline the brakes, very cheap if done through the BNMC hint hint.
PostPosted: Wed Jun 05, 2013 9:47 am    Post subject: Reply with quote
The Dodge has rear brakes only. Adjustment had been taken up on the centre rod that connects the pedal to the rear equalising bar, so much so that they only really did anything with the pedal right down. Disconnecting the main pull rod and adjusting each wheel independently before reconnecting the main rod improved things no end.
Cluley
PostPosted: Wed Sep 25, 2013 12:54 am    Post subject: Morris Cowley Reply with quote
I have one of these 1931 model Flatnose Cowleys with the taller radiator which I have owned for 32 years. Mine has 5 doors, but is otherwise no different.
The rod braking system on mine is excellent and I have never found the steering to be particularly heavy. I would advise checking tyre pressures and greasing the steering. Front tyres I keep at around 34 PSI.
On the braking, I strongly suggest checking for leakage from the oil seals on the rear hubs into the brake drums. I had this problem many years ago and it did make the brakes less effective, though still far better than the Austin 7 that I had previously.[/i]
PostPosted: Wed Sep 25, 2013 6:57 am    Post subject: Reply with quote
Hi Mike,
Have you found any good sources of spares for the Cowley?
NONORT
PostPosted: Wed Sep 25, 2013 2:21 pm    Post subject: Reply with quote
Hi Mike
By far the most reasonable supply of parts will come from The Bullnose Morris Club or Cooke of Leicester. No connection with either apart from being a club member of the former and a customer of the later.
PostPosted: Wed Sep 25, 2013 2:28 pm    Post subject: Reply with quote
Interesting that there are a few flatnose Morrises on here, any chance of photos?
PostPosted: Thu Sep 26, 2013 11:19 am    Post subject: Reply with quote
Probably teaching granny to suck eggs but it's most important that the levers on the brake shafts don't go past the 90 degree point when fully applied.
PostPosted: Thu Nov 20, 2014 8:39 pm    Post subject: Reply with quote
Hi MikeC, just thought I'd bounce this thread back up - how's life with the Cowley (assuming you still have it)?
Ocheye
PostPosted: Thu Nov 20, 2014 8:51 pm    Post subject: Reply with quote
I've just changed my tyres for Longstone 400/45 as my 'good' tyres hadn't been used for 35 years. I'm led to believe that they make a significant difference to the steering. The car isn't on the road yet so I can't vouch for them personally. However, pushing it around at home is significantly lighter. With the old tyres I had tennis elbow for weeks after manoevring it. The Chairman of the Bullnose Club and his daughter both use them and are very impressed
PostPosted: Sun Jan 04, 2015 10:42 am    Post subject: Reply with quote
I've just caught up with this thread!
No, Rick, I have sold the Cowley; it proved a great disappointment; even after I had improved the performance greatly by resetting the advance it was still desperately slow, and just didn't inspire that little something that was needed... A shame, really, as it was in beautiful condition, it just wasn't for me.
I'm an Austin man at heart, so it looks like it's back to an Austin Seven next (unless something else jumps out and tempts me!).
PostPosted: Sun Jan 04, 2015 11:00 am    Post subject: Reply with quote
Interesting, what kind of cruising speed was it happy at?
I remember my 34 Minor saloon was fairly leisurely, I'm hoping that the open two-seater - with its lighter body - will be a bit perkier.
