Uncle Joe Guest
Posted: Tue Jul 25, 2006 2:20 pm Post subject: Restoration Book |
Over the past few weeks, it has been suggested to me by several people that I use my experience in restoring vehicles to write a book on the subject, aimed at people with a limited budget (ie all of us!).
What I would like to know is what would you all like to see in such a book?
And do any of you have any opinions on the subject? |
Posted: Mon Jul 31, 2006 5:15 pm Post subject: |
Just to chime in here, sounds like a great idea!
Rick |
Uncle Joe Guest
Posted: Mon Jul 31, 2006 6:31 pm Post subject: |
Thanks for the kind reply, Rick.
Come on, you others out there, tell me what you would like to see in it. All suggestions are welcome! |
Posted: Fri Aug 04, 2006 6:32 pm Post subject: |
What chapters do you have in mind to include in the book???
Rick.
Uncle Joe Guest
Posted: Sat Aug 05, 2006 2:09 pm Post subject: |
At present, I´m thinking of splitting the book up into 5 sections, with chapters in each.
Section 1: Introduction
Section 2: Getting Started. Owners clubs, websites, tools, safety, etc.
Section 3: Cosmetic. Welding, painting, body soldering, upholstery, etc
Section 4: Mechanical. Electrics, engine, transmission, etc.
Section 5: Upgrades. Electronic ignition, 12 volt conversions, etc.
Section 6: Maintenance. Minor repairs, sevicing, etc.
How does that sound? |
Rivet_101 Guest
Posted: Tue Aug 08, 2006 12:56 am Post subject: tricks |
I'd be looking for those hot tips for easing really solidly stuck parts, dealing with rust, etc.
Nothing I have tackled so far has unscrewed without a fight.
Currently I am trying to get pistons out of wheel cylinders. The cylinders are cast aluminium and the pistons are steel; bugger of a combination.
I have tried the trick of popping them in boiled water and leaving them for 5 minutes, without success. Tomorrow I am soaking them in paraffin. |
Uncle Joe Guest
Posted: Tue Aug 08, 2006 7:47 am Post subject: |
My usual trick with wheel cylinders is to soak them overnight in bulk WD40 or similar, then warm them with a blowtorch the following morning, paying special attention to the cylinder / piston gap. I then try to blow them out with compressed air. if it doesn´t work the first time, I then just spray the gap, heat, and try again.
Its a bit of a butchers method, because obviously it wrecks the rubbers, but has never failed me! |
coolcon Guest
Posted: Sun Aug 13, 2006 6:40 pm Post subject: |
| Go for it Joe! |
Floride Guest
Posted: Sat Aug 26, 2006 10:41 pm Post subject: Restoration book |
Good idea but please do some research into what is already out there. The ones I have seen show you how to restore the easy stuff like Minors and MGS, how about the harder ones where there is virtually nothing and you have to make from sheet steel and roll of upholstery material.
I was going to tackle something very similar a couple of years ago but could not find a publisher who wanted something that indepth. A limited market.
My later thoughts were a CD/DVD and even a complete internet site. |
buzzy bee Guest
Posted: Sat Aug 26, 2006 11:30 pm Post subject: |
Lots of tips on welding to really thin tin and spray painting tips, or even ways to get best results brush painting would be good.
Also tips on cleaning interiors and even cleaning/restoring old paintwork. |
Uncle Joe Guest
Posted: Sun Aug 27, 2006 12:14 pm Post subject: |
The idea of the hard stuff is a good one, that was brought to my attention when I started on my Lincoln, parts just aren´t available for it, so a lot has to be made / modded.
I have been thinking about either a subsciption only website, or possibly even publishing myself.
At present, I´ve got 3 chapters more or less complete, spray painting, repairing body mouldings, and body soldering. At present I´m working on maintenance and welding thin sheet. I can get down to welding 20-25 thou. Is that thin enough for you, buzzy?
Coachpainting I´ll have to think about, but upholstery from scratch will definately be included - my wife gas just bought out a Trimming Company, with my money! |
buzzy bee Guest
Posted: Sun Aug 27, 2006 6:50 pm Post subject: |
Trimming company - sounds handy but expensive!
I think that is thin enough for me!
Body soldering would be really interesting, allways wanted to find out more about that. |
Uncle Joe Guest
Posted: Sun Aug 27, 2006 7:11 pm Post subject: |
Buzzy, I could teach you Body Soldering basics pretty quickly, and then the only thing that you would have to do is practice.
UJ |
buzzy bee Guest
Posted: Sun Aug 27, 2006 7:55 pm Post subject: |
| Sounds interesting! I have not found many people that are willing to do it around here. |
Uncle Joe Guest
Posted: Sun Aug 27, 2006 8:11 pm Post subject: |
| buzzy, as you possibly know from Rick, I live in foreign parts. If you wish, we can set something up next time I am over. (Autumn). Maybe through Rick? |
