Posted: Tue Jun 11, 2013 9:37 pm Post subject: Rev Counter. |
Mine has never worked since I got the car. Any ideas anyone where I should start looking for the fault.? _________________ The Clan Chieftain |
Posted: Tue Jun 11, 2013 11:49 pm Post subject: |
Larry,
Is it an original equipment or an aftermarket. The Smith type uses the coil feed wire from the ignition switch. At the rev counter there is a 'U' shaped piece with the wire looped once around. As the contacts open and close it generates a small magnetic field in this 'U' piece. If yours is this type check that there is an air gap between the poles (the sides of the 'U').
Posted: Fri Jun 14, 2013 12:00 am Post subject: |
Now working...............thanks Art. _________________ The Clan Chieftain |
