1936 Riley 9 Merlin
rjt10/4
PostPosted: Mon May 13, 2013 1:15 pm    Post subject: Reply with quote
At last i can make an update progress has been a bit slow but fabrication has started on making up the body mounts
rjt10/4
PostPosted: Wed May 15, 2013 3:19 pm    Post subject: Reply with quote
a further update great things are happening fabrication on passenger side sills and mounts is progressing nicely
rjt10/4
PostPosted: Mon Jun 17, 2013 7:25 pm    Post subject: Reply with quote
At last a further update the panel fabrication is coming along nicely one inner rear wing has been done boot floor has been straightened rear mounts done and a start made on other inner wing progress was held up by work on my armstrong saphire
i hope you like the update more to follow
PostPosted: Mon Jun 17, 2013 7:30 pm    Post subject: Reply with quote
I do like. Nice neat workmanship. The car will be strong and straight again.
rjt10/4
PostPosted: Thu Jun 20, 2013 12:24 am    Post subject: Reply with quote
Both inner rear wings now done just passenger side sill to be finished and all major welding should be done
Kelsham
PostPosted: Thu Jun 20, 2013 8:49 am    Post subject: Reply with quote
The work looks first class, I am glad you decided to restore the saloon body. A wise decision if the weather keeps on its present course.
I scuttled back from a local show recently under the prompting of a heavy shower.
I worked on a Riley Adelphi some years ago, they are beautifully made.
Regards Kels.
rjt10/4
PostPosted: Mon Jun 24, 2013 9:35 pm    Post subject: Reply with quote
a further progress update door bottoms have had new wood scarfed in and now as strong as ever unusually the top of the doors are steel and bottoms are ally rear wheel arches have been skimmed and stone chipped
sorting out the running gear ready to refit sometime in the next couple of weeks i hope you all like the updates
rjt10/4
PostPosted: Tue Jun 25, 2013 11:08 pm    Post subject: Reply with quote
another quick update the underside of body has now had its first coat of waxoil so looking good was zinc coated when blasted and 2 coat of primer then waxoil so should be good for at least a few years yet
it was decided to give axels and running gear a fresh coat of paint prior to refitting
plenty more updates to come so watch this space
rjt10/4
PostPosted: Sat Jun 29, 2013 10:35 pm    Post subject: Reply with quote
at last the Riley is starting to look like a car again running gear has been refitted as has the engine and gearbox propshaft connected unfortunately no work will be done for about a month due to his other customers requirments and staff shortages
more as it happens
rjt10/4
PostPosted: Thu Jul 18, 2013 4:12 pm    Post subject: Reply with quote
the only progress to report is that i took all the chrome items to be re chromed over to the platers S & T in Yate nr Bristol who have come very highly recommended price came in at £3000 so i hope it's worth it will update soon
rjt10/4
PostPosted: Wed Sep 11, 2013 6:11 pm    Post subject: Reply with quote
picked up most of the chrome from S&T platers and pleased to say they have made a first class job just awaiting the radiator shell and headlight bowls also the upholstery is off to trmmers to be rebuilt using leather as originally will post some more pics soon as i can
PostPosted: Wed Sep 11, 2013 8:06 pm    Post subject: Reply with quote
Great to watch it coming together so well, and to see a saloon being resurrected rather than a special being built up from its under-garments.
rjt10/4
PostPosted: Fri Sep 20, 2013 2:59 am    Post subject: Reply with quote
picked up the last of the chrome work from S&T platers today i hope to get some pics tomorrow headlight bowls look fantastic having been re silvered not seen the Riley for 10 days so hopefully some progress has been made
PostPosted: Fri Sep 20, 2013 6:58 am    Post subject: Reply with quote
Do you have a target deadline for completion?
rjt10/4
PostPosted: Sat Sep 21, 2013 8:32 pm    Post subject: Reply with quote
hi Rick i have asked if the Riley could be ready for Easter and was told no problem but he didnt say which easter? so watch this space
Page 2 of 4
