clogs
Posted: Sat Jun 22, 2013 7:38 pm Post subject: opening windscreen |
Hi out there.....
can anyone recommend anybody to fabricate a new opening windscreen surround....
I would prefer brass or stainless.......the vehicle is a 1930 C4 Citroen..
If u look at photos u will see that all the corners are rounded and the lower
edge is also rounded / arched to follow the shape of the bulkhead...
I had decided to cut it from a stainless sheet ie...inner and outer edges with a third filler strip tig welded to hold them apart and form the outer edge....
any ideas......I don't fancy a weeks work with a jig saw and a draw file shaping them and who knows what it will twist like when welded....
''but if needs must.''
cold formed would be ideal.......any ideas.....
thanks Frank Cloggs |
traction39
Posted: Sat Jun 22, 2013 8:20 pm Post subject: |
Wessex workshops in Wilts advertise in The Automobile as fabricators of windscreens. You could try them. 01373 823513.
I have no idea about their work...worth a call?
Alistair |
