3xpendable
Posted: Tue Jul 30, 2013 6:49 pm Post subject: |
Thanks Rick
Well, onto the MG. After much, MUCH cursing, the engine is in, hooray!!!
We got it in fairly easily & qucikly but then spent 3 hours trying to get the engine mounts bolted up. Bearing in mind that I paid for all the proper MGB V8 engine mounts and parts, nearly all the bolts AND the studs on the mounts were far too long and had to be cut down. Anyone who knows the later MGB's knows that the mounts are angled on the chassis, and therefore with studs too long, you cannot get the nut on...so why? Why when you pay for fortune for V8 conversion parts do they still not fit? I was fuming for quite a few hours, but here it is:
I've also wrapped up the tyres et as they get warm in this weather:
I am now stripping the cylinder heads and cleaning them up, along with making a crossmember to suit the new gearbox. _________________ 2013 Dodge Durango R/T Hemi
1965 Ford Anglia 106e Estate (LHD)
1964 Ford Anglia 105E 1500 GT (Dad)
1980 Porsche 911 SC Targa (Uncle)
1971 MGB GT (V8 project) -SOLD 2016
2005 MINI Cooper S JCW - SOLD 2016 |
3xpendable
Posted: Wed Aug 07, 2013 12:32 pm Post subject: |
Cylinder head cleaning is coming on well, using copious amounts of Mr Muscle oven cleaner after the cleaning tank failed to clean much off. Here is a chamber before:
And one after
Exhaust ports are mostly cleaned save for the intricate bits
Here is a before and after rocker, again Mr Muscle works great!
I had to take the steering rack off today to fit the nut to the engine mount that side, thank you BL engineers.
3xpendable
Posted: Sat Aug 24, 2013 11:54 pm Post subject: |
I'm beginning to have a dilemma with the car now and i'm trying not to get too down about it.
Basically my parents divorced recently, and my dad has now moved away from where the MG is. Given that I can only go there one weekend a month or so to work on it i'm not so sure much is going to get done on it now. I'm contemplating putting it in storage until I have somewhere for it and can finish it on my own.
It sucks really... _________________ 2013 Dodge Durango R/T Hemi
JC T ONE
Posted: Sun Aug 25, 2013 3:10 am Post subject: |
Sorry to hear hope you get it sorted. _________________ http://www.eurods.eu/wp/index.html |
Posted: Sun Aug 25, 2013 11:11 am Post subject: |
What part of South Wales are you? I might have contacts |
3xpendable
Posted: Sun Aug 25, 2013 6:40 pm Post subject: |
D4B wrote: | What part of South Wales are you? I might have contacts |
I'm in South West Wales, what sort of contacts are you thinking?  _________________ 2013 Dodge Durango R/T Hemi
Posted: Sun Aug 25, 2013 7:05 pm Post subject: |
Welshie wrote: | D4B wrote: | What part of South Wales are you? I might have contacts |
I'm in South West Wales, what sort of contacts are you thinking?  |
I know a few people in South east Wales I just thought perhaps we could
have found you an alternative workshop for your project...
However tis a bit too far from you Doh !!
Good Luck with it  |
3xpendable
Posted: Sun Aug 25, 2013 8:56 pm Post subject: |
D4B wrote: | Welshie wrote: | D4B wrote: | What part of South Wales are you? I might have contacts |
Good Luck with it  |
Don't write it off yet, I was until recently based in Cardiff so PM me what you were thinking  _________________ 2013 Dodge Durango R/T Hemi
3xpendable
Posted: Thu Sep 12, 2013 6:22 pm Post subject: |
Well my brother is now off work, so he's given me a few tips and new motivation on the car, so here goes! The red oxide primer was cracking in places, powdery in others and so I decided to just sand the whole car down. I've done it with wet and dry and in most places its come off pretty easily, so my pink MGB is now yellow (the cars original colour).
Where is hasn't come off, it looks solid enough so am just keying it. So far over the last two days I've done this much
Hoping to finish the other wing off tomorrow, then the roof and scuttle etc next week.
I've also been researching cylinder head upgrades such as porting etc. The heads are going off to my friend to have the valve seats ground and then I'll finish cleaning the ports and do any port matching that's required. _________________ 2013 Dodge Durango R/T Hemi
3xpendable
Posted: Thu Oct 17, 2013 7:48 pm Post subject: |
Primer is on, and its all one colour Flatted it back today and found a few dinks so will be sorting them out tomorrow, hopefully it gets topcoat on the weekend then!
Joined: 23 Nov 2007 Posts: 4240 Location: South Cheshire
Posted: Thu Oct 17, 2013 11:45 pm Post subject: |
Getting the car all one colour (even primer) Really gives you inspiration; the restoration now becomes a build
Well done for doing all the hard work and getting this far
I too look forward to seeing it painted.
3xpendable
Posted: Sun Oct 20, 2013 8:48 am Post subject: |
Thanks guys.
Flatting back showed up a few issues and as it was only 1 layer of undercoat it went through in some places. So after another 1/2 day or so of fettling, dad put on 4 layers of undercoat yesterday and all looks good. Its being left to harden today before the car gets moved to our makeshift spray booth and gets fully masked up ready for paint next weekend, if the weather isn't too damp.
In between all that, in repayment for all his hard work, i'll be helping my brother fit his freshly built 998cc engine into his Hillman Imp during the week, now that the workshop is free and all. _________________ 2013 Dodge Durango R/T Hemi
Posted: Sun Oct 20, 2013 12:23 pm Post subject: |
I had the same problem; going though to metal when I flattened the mga's primer, you need to determine if it's a "real" high spot that needs dealing with, before re-priming; I had a few of them !!
I also used to have an aerosol of primer to hand, to touch up anywhere where I had gone through.
