Austin A55 pick up 1961
davebess
PostPosted: Sat Dec 17, 2011 11:31 am    Post subject: Austin A55 pick up 1961 Reply with quote
i would to find out , if anyone here, owns a Austin A55 pick up . i will be a luck person ,who hopefully will be having it left to me in a will. I have a view that it will stay in the family . up until 3 years ago it was always mot, but i need to do the clutch seals and it is not working , because it not be moved for 2 years. i will post photo's soon. where can i get spares ? sorry lots of question in my first post.
Dave Rolling Eyes
PostPosted: Sat Dec 17, 2011 1:47 pm    Post subject: Reply with quote
Welcome to the forum Dave.
Mechanical parts shouldn't be a problem, keep an eye on ebay as most of the running gear will be shared with the contemporary Austin Cambridge saloons. If you get stuck, specialists such as Earlpart will probably be able to help with most things, but there are quite a few traders out there who specialise either in BMC (Austin, Morris etc) cars, or specific parts for all cars (eg clutch seals, wheel bearings and similar).
It might be worth picking up a few classic car and van/pickup type magazines, that'll give you a head start with identifying the best suppliers of parts.
rgds, Rick
PostPosted: Sat Dec 17, 2011 4:16 pm    Post subject: Reply with quote
Hello Dave,
I have an A55 MK1 saloon. Earlpart are your best bet for parts, mechanical bits are mostly the same as the A55 MK2 and other Farinas and are quite reasonably priced. Body panels are very rare, front wings are made from unobtanium (although fibreglass ones are avaliable). Doors and window seals are unavaliable, as are most of the pickup rear panels. Open the bonnet and check the inner wings carefully for rot or poor welding as there is a terrible mud trap with the box section behind them. If you look under the front wings there are two ventilation holes in the box section at the top, these allow mud and salt to get into the box section and sit there until it rots out into the engine bay! If it's sound in this area get some wax in there and get those holes sealed off pronto.
Obviously then it's the usual, sills, spring hangers, front crossmember behind the fairing panel, outriggers (check a triangular plate hasn't been welded over the rusty originals to pass an MoT) and the usual engine checks.
Richard Hughes
PostPosted: Sun Jan 15, 2012 4:50 pm    Post subject: Reply with quote
Any more news on the pickup Dave?
PostPosted: Thu Sep 12, 2013 12:01 pm    Post subject: Reply with quote
Dave, any updates on the A55 - did you get to put it back on the road in the end? Earlier in the year I went for a nosey at a one-owner pickup I'd seen advertised, tucked away in the corner of a timber yard under a lean-to - it wasn't a pretty sight so I beat a hasty retreat Smile
PostPosted: Tue Sep 17, 2013 11:17 am    Post subject: Reply with quote
Small van prices have shot up, easy to fit in your drive or garage and are always useful. Always like d the A55 van but wouldn't mind the panel van version.
