Morris 8 Series E 1948
Gjneves
PostPosted: Mon Oct 14, 2013 5:21 pm    Post subject: Morris 8 Series E 1948 Reply with quote
Hello,
I have a Morris 8 from 1948 that is restored about 5 years. I'm from Portugal.
However it has a electrical problm that was solve replacing dynamo with alternator with 2 bateries. It charge a 12v But work at 6v. but a few months have stoped working.
Now i will try to fix it by restore original Dynamo and control box. But I need help!
I need the electrical diagram!
Thanks
Gonçalo Neves
PostPosted: Mon Oct 14, 2013 5:32 pm    Post subject: Reply with quote
Welcome to the forum - lovely car, hopefully someone will have a wiring diagram to help you (I don't think I have one, but I will check).
PostPosted: Mon Oct 14, 2013 7:37 pm    Post subject: Reply with quote
gorgeous car. hope you find the help you need
kev
hunsta
PostPosted: Tue Oct 15, 2013 12:04 am    Post subject: Reply with quote
I have wiring diagram for the E series. As soon as I work out how to copy a page from a PDF file Ill post it. And yes nice car. Hope my 48 turns out as good.
I really am a nice guy. Just ask anyone that hasn't met me.
TribalElder
PostPosted: Tue Oct 15, 2013 6:52 am    Post subject: Reply with quote
Hope you can read this Smile
Ian from Oz
It's hard to run like an Emu
When you are girt by Numbats
PostPosted: Tue Oct 15, 2013 9:17 am    Post subject: Reply with quote
Hi Ian,
I know that all car wiring diagrams are much the same but that doesn't really look like it was for a Morris 8 SE!
Here's a closer version..
TribalElder
PostPosted: Tue Oct 15, 2013 9:24 am    Post subject: Reply with quote
Ha ha ha, you're right Rolling Eyes
I sent the wrong one Embarassed
My humble apologies Shocked
Ian from Oz
hunsta
PostPosted: Tue Oct 15, 2013 9:46 am    Post subject: Reply with quote
Laughing Um just to through another spanner into the works. Seeing as the car is in Portugal and left hand drive, would it not come under the export model wiring diagram? I have both on my manual, but can copy individual pages as its on a PDF file that has a security lock.
Gjneves
PostPosted: Tue Oct 15, 2013 8:18 pm    Post subject: Reply with quote
Thanks a lot!!
I seach in web but only find techical Service Sheet in (www.morris8cars.zxq.net) but don't have electrical diagram. If you know where I find more usefull techical information please tell me where is it to buy it or download.
Now, I will buy a dynamo and try to fix it. I already buy a voltage regulator in ebay. It isn't easy to find it with good price! I don't know the state of it, it's easy to fix?
Thanks,
Gonçalo Neves
PostPosted: Wed Oct 16, 2013 10:15 am    Post subject: Reply with quote
Hi Gonçalo,
The diagram I posted appears in various books but a very inexpensive source would be this little book:
http://www.abebooks.co.uk/servlet/SearchResults?an=abbey&bt.x=65&bt.y=15&sts=t&tn=Morris+eight+and+the+morris+minor
hunsta
PostPosted: Wed Oct 16, 2013 11:30 am    Post subject: Reply with quote
Heres one I bought. Comes with lots of extra`s. And only GBP 3.45 +
postage
http://www.ebay.com.au/itm/Morris-8-eight-Series-E-Companion-Lucas-Maintainance-/360746345885?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53fe28659d
bjacko
PostPosted: Wed Oct 30, 2013 9:22 am    Post subject: Reply with quote
Go to www.moreg.org.au/wiring_diagrams.htm
Gjneves
PostPosted: Thu Oct 31, 2013 5:40 pm    Post subject: Dinamo Reply with quote
Hy,
I already found a dínamo and 2 voltage regulator for my Morris 8.
However i have a problm with a Dínamo.
If i change the front cover it don't aligned the hubs.
Can you have an idiea?
Gonçalo Neves
Gjneves
PostPosted: Wed Nov 27, 2013 2:39 pm    Post subject: Horn buttom Reply with quote
Hy guys,
I need to remove the horn and trafic switch from the steering wheel, i already remove the smal screw down slide from the steering but the all piece don't out. Please tell me If i was forgeting any else?
Gonçalo Neves
PostPosted: Wed Nov 27, 2013 2:58 pm    Post subject: Reply with quote
If it is like the Austin A40 Devon I used to own (1949), there is a small nut on the bottom of the steering box which needs removing before the switch, horn button, and the tube down which the wiring passes, can be pulled up and out of the column. Maybe the Morris is similar?
