Sand blaster
GaryParnell
PostPosted: Mon Dec 09, 2013 9:15 pm    Post subject: Sand blaster Reply with quote
Any one used one of these? Are they any good?
http://item.mobileweb.ebay.co.uk/viewitem?sbk=1&nav=SEARCH&itemId=120617091127
Thanks
Gary
PostPosted: Mon Dec 09, 2013 9:25 pm    Post subject: Reply with quote
I have a similar one, the problem is the mess, it either needs to be used outside; where you can get away with leaving the mess, or in a completely empty garage where it can all be swept up. The air needs to be bone dry as does the media otherwise it will keep clogging up!
PostPosted: Tue Dec 10, 2013 12:15 am    Post subject: Reply with quote
The other problem is the cost of suitable media, unless you live near a nice sandy beach Wink
Rosco663
PostPosted: Tue Dec 10, 2013 3:29 am    Post subject: Reply with quote
Gary,
The practical tips on using this type of sandblaster are quite valid. I don't want to seem to be an old fun stopper Embarassed but you also need to consider the safety aspects as well, particularly if you intend to use beach sand (silica sand). I found the following link which should help guide you through. Even better to do your blasting in a blasting cabinet or booth.
http://www.manleybros.com/safety2.htm
Rosco
GaryParnell
PostPosted: Tue Dec 10, 2013 9:53 am    Post subject: Reply with quote
Thank your for your replies I have got a cabinet which is homemade and has an extractor, I also used glass as the media
Thanks very much
Gary Parnell
