Joined: 30 Apr 2013 Posts: 4324 Location: The Somerset Levels
Posted: Mon Dec 16, 2013 5:16 pm Post subject: Millboard |
Yesterday afternoon I measured up the door cards from an old Commer lorry that I am restoring, in order to make replacements. They measure roughly 6mm thick but I have noticed that replacement Millboard these days is 3mm thick.
Lorry door cards are just painted without being covered and I was just thinking that 3mm seems a little too thin?
Any thoughts? |
Posted: Mon Dec 16, 2013 6:08 pm Post subject: |
| Glue two thicknesses together, possibly? |
ajlelectronics
Posted: Tue Dec 17, 2013 2:18 pm Post subject: |
Two options:
1) Use 6mm Foamex board. Waterproof and lightweight, easy to work.
2) Use 1/4" foam and plain vinyl and improve the door cards, unless it is going to be concourse? _________________ Evans Waterless Coolants
Posted: Tue Dec 17, 2013 3:52 pm Post subject: |
We have some foamex board where I work so I will have a look at that. I did wonder about either glueing or just placing one sheet of millboard on the top of another and screwing in place.
I think the trouble with one thickness is that the inner face of the door is not flat, it has ridges and louvres etc and I think a board that is thin and flexible may be pulled out of shape when tightened on these features. |
