alecmcd Guest
Posted: Wed Jun 27, 2007 6:41 pm Post subject: Help needed with a smokey MGB Roadster |
| I have a 1972 MGB, which +had a new goldseal block 17 years ago during the restoration, and was then gararged for 16 yeras. Since coming out of mothballs, the car has been performing very well, but every now and then it blows out the exhaust large amounts of grey smoke. I have checked the oil level and have topped it up recently, but the level is just on ful on the dipstick. The problem only occurs when the engine is hot, and has been running for a few mins. Last time it happened on a motorway, and so I pulled off, and after 200 yds the problem went away and it again ran as sweet as a nut. If the problem persisted then I would assume that it was a cracked block/head, or a broken oil ring, but the strange thing is that the problem only lasts for about 30 seconds and then rights itself. Has anyone ever come across the same problem before, especially on a 1800 cc MGB engine?, does anyone have any ideas |
Brian M Guest
Posted: Thu Jun 28, 2007 9:19 am Post subject: |
Rick and Alec
I had a similar problem on one of my BMW 3 series - it blew out a smokescreen after a hard run when coming off the throttle. Especially when slowing down on a motorway run.
It was easily cured by replacing the valve stem seals. Somehow oil was being sucked down into the cylinders when there was "negative pressure" in the cylinders.
On an engine that has not been used for many years I would look at the seals first. |
UKdave2002 Guest
Posted: Tue Jul 03, 2007 4:02 pm Post subject: |
Hi Alecmcd
Also....
I'd check any rubber breather / induction /brake servo hoses; you may find they are deteriorating from the inside, with bits finding their way into the engine and burning up, also check the fuel is new and, nice and clean, old petrol can do odd things, again check not dragging contaminants into the engine.
If the valve stem oil seals are failing you will get the smoke as others have said on over run (when you decelerate), but it would normaly be more consistent than you describe and more a short blast of smoke each gear change and a consistent blast when you decelerate .
If it was a broken ring you would expect it to be worse when the engine is cold.
Good luck
62rebel Guest
Posted: Thu Jul 05, 2007 6:06 pm Post subject: |
| are those skinner's union carbs, and mightn't the gaiters be perished by now? know my old spit and my triumph used to eat the darn things regularly. the B i had was never on the road while in my possesion, so if it's were bad i didn't know it. |
UKdave2002 Guest
Posted: Thu Jul 05, 2007 6:10 pm Post subject: |
Hi 62 rebel, what do you mean by gaiters? ....there is nothing to perish on SU carbs? are you thinking of variable choke strombergs ?
Cheers Dave |
chimpchoker Guest
Posted: Thu Jul 19, 2007 2:33 pm Post subject: |
is it grey smoke or white smoke? I once had a servo put on my mini and when it knacked up it was sucking the brakefluid into the engine and burning off with a grey whiteish cloud of smoke every now and then but when the brakes were pushed very hard. Light pushing of the brake pedal was ok.
Also isn't burning oil a blue colour in smoke?
TC
Aaln |
