fuel catalyst
PostPosted: Wed Jan 08, 2014 10:45 am    Post subject: Reply with quote
AFter years of messing about with engines of all types and sizes the only additive I've found that works is two stroke oil added to diesel. It quietens and smooths the engine and gives slightly better economy. I guess it works because the new fuel is less 'oily' than the old and at the risk of gassing polar bears and being personally responsible for glaciers vanishing I have used it for the past five years.
PostPosted: Wed Jan 08, 2014 11:59 am    Post subject: Reply with quote
In fact, you're probably responsible for glaciers re-forming over North America and polar bears allegedly suffering with the cold. Wink
PS. Just heard that Hell has frozen over (the town in USA).
I never stress on the many occasions when I have had to resort to my chainsaw two-stroke fuel can to power my old Austin (faulty fuel gauge). Modern two stroke seems hardly to smoke at all and in my "un-scientific" mind I just think of it as Redex. In principle I agree with most of the posts here in that bits of lead dropped randomly into a fuel tank without calibration and for unspecified and varied periods of use is probably pointless and just as "un-scientific."
emmerson
PostPosted: Wed Jan 08, 2014 5:54 pm    Post subject: Reply with quote
Sorry BD, I can't let you claim the privilege of gassing polar bears.
According to my neighbour, I am personally responsible for all the ills in this world because I drive a V8 Range Rover. The fact that it runs on emission-free LPG does not impress her at all.
She does admit that it is handy in the snow, when she needs shopping done.
Now, how do I put snake-oil in my LPG tank?????? Laughing
PostPosted: Wed Jan 08, 2014 8:02 pm    Post subject: Reply with quote
I never saw one, but a few years ago when LPG was being touted as the next big thing, there was a widget around for supplying an engine running on LPG with small amounts of one or another of the "lead replacement" petrol additives. If you could track one down it would probably work just as well with snake oil Laughing
norustplease
PostPosted: Wed Jan 08, 2014 10:48 pm    Post subject: Reply with quote
A lot of LPG systems have a reservoir and valve that will bleed small quantities of upper cylinder lubricant (flash lube) to prevent valve recession. Your local fitter can probably modify the system if you have an engine that does not have sufficiently hardened valve seats.
As for fuel catalysts and other wonder patent devices, my advice would be to spend your money on a proper tune up instead.
1953 Citroen Traction
1964 Volvo PV544
1973 VW Beetle 1303L
Boring Suzuki SX Hybrid
PostPosted: Wed Jan 08, 2014 11:26 pm    Post subject: Reply with quote
I covered 150,000 miles on lpg, no additives and the engine still ran sweet when I sold the car.....did get through a couple of coil packs and ignition lead sets, plugs needed changing every 10,000 miles...shame there is no snake oil spray, I'm convinced if there was it would have doubled the life of the HT components Wink
norustplease
PostPosted: Thu Jan 09, 2014 12:16 am    Post subject: Reply with quote
Likewise, I had two Subaru Legacies, one after the other that I ran almost exclusively on LPG. No flash lube, because the system that Subaru used was a high pressure system that delivered the LPG as a liquid rather than as an atomised gas, which theoretically kept the valve seats cool. It was, however, part of the 12k service to check the valve clearances, which would otherwise not have been required on a petrol only model.
Don't think that Subaru do LPG conversions any more, it was a stopgap measure whilst they sorted out a diesael option, petrol Scoobies being such thirsty beasts.
Valve recession can be a problem on some cars, however, particularly older models, and the flash lube apparently helps. Theoretically your engine should wear less in terms of bore wear, since there isn't any liquid petrol to wash lubricant off, apart from when the engine starts from cold. Whether this works in practise, I am not sure, however.
1964 Volvo PV544
ka
PostPosted: Thu Jan 09, 2014 8:49 am    Post subject: Reply with quote
As I think we have decided that red-ex is the future, and that we are all responsible for the polar ice, I have decided to make two enquiries.
1). I intend to buy shares in Red-Ex
2). I am writing to the Governments of the world requesting my share-pack in the Antarctic, to ensure that when the drilling starts, and they find oil in the ice, I own a part share of it.
Now where were those air borne pigs, we need bacon........
KA
Better three than four.
ajlelectronics
PostPosted: Thu Jan 09, 2014 11:28 pm    Post subject: Reply with quote
Never heard of WD-40? Wink
Evans Waterless Coolants
ka
PostPosted: Fri Jan 10, 2014 10:31 am    Post subject: Moisture Dispersants Reply with quote
There is no doubt that the first choice for many when looking at a damp ignition system, or seized nuts is to give a liberal spraying of the well known compound.
I have found it a good moisture disperser, but prefer a more purpose made de-seizing compound.
I know that many people use the same product to give weather protection on exposed parts.
In our club, we have a member who is also a development scientist for a major lubricant company, who wrote a very interesting article on dispersant sprays, and that some of them, whilst giving excellent moisture reduction properties, are corrosive when used on exposed alloys and metals.
My point is, select the correct potion for the ailment.
KA
PostPosted: Fri Jan 10, 2014 11:47 am    Post subject: Reply with quote
Excellent as WD40 is, it can not, unfortunately restore insulation that is beginning to break down on HT components !! Smile
ajlelectronics
PostPosted: Fri Jan 10, 2014 8:57 pm    Post subject: Reply with quote
The only thing it is excellent at is convincing people that it is anything but the 40th attempt to create a water dispersant.
robo0121
PostPosted: Sat Jan 18, 2014 5:41 pm    Post subject: fuel catalyst Reply with quote
thats a no then.???
PostPosted: Mon Feb 10, 2014 6:37 pm    Post subject: Re: fuel catalyst Reply with quote
robo0121 wrote:
thats a no then.???
Seems that way
Rosco663
PostPosted: Wed Feb 12, 2014 2:41 am    Post subject: Reply with quote
We all know that WD-40 is a good all rounder in the workshop but isn't a strike bowler or opening batsman.
Back to the topic of fuel catalysts, has anyone heard of the Energy Polariser - pushed heavily in the 1980's more famously by one Mr Peter Brock of racing fame. It would put any Snake Oil to the test Cool
Here is a brief summary of how it works:
"An Energy Polarizer transmits a high energy mainly generated by the vehicle to which it is attached.
This high energy field - A.B.A. Energy - causes all molecules in it's sphere of influence to be aligned or polarized to the direction of the high energy transmission, and are held in a linked or aligned state.
These molecules are subject to a vibratory rate dictated by the Polarizer.
The printed circuitry in a Polarizer causes a multiplicity of frequencies to be transmitted, affecting each molecule and allowing that molecules and it's environment to absorb specific vibration levels including noises, vibrations resonance and impact harshness which are always present in any vehicle and also to dampen out the effects of imperfect manufacture of vehicle components.
The overall effect on a motor car is to absorb road shocks more completely and quietly, to reduce overall vehicle noises - both inside and outside - to achieve greater efficiency of the power train and steering systems, improving the engine and suspension performance and to create a more pleasant environment for the driver and passenger.
Certain frequencies have not been "tuned out" as they are necessary for increased road safety.
The energy transmitted from the "Energy Polarizer" always flows to that area most effected. That means a major problem area still remains a problem, and the energy is effectively wasted on that area since the overall vehicle is deprived and consequently is less enhanced. So a correctly manufactured and maintained vehicle will always be superior to one that is not, but all vehicles benefit from the fitment of an Energy Polarizer.
It should be noted a vehicle which normal requires high octane leaded fuel is then able to operate on low octane (92) unleaded fuel, without any ill effects whatsoever, when an Energy Polarizer is fitted.
from http://performanceforums.com/forums/showthread.php?67151695-Peter-Brock-s-Energy-Polariser
Rosco
Page 2 of 3
